[mapguide-internals]MapGuideRFC19-ConcurrentFDOproviderconnections
Bruce Dechant
bruce.dechant at autodesk.com
Thu Apr 19 12:53:32 EDT 2007
Paul,
This is not a hack. It actually does handle the problem. Perhaps my
example was not clear. I can update the RFC with more examples and more
detailed explanation.
The settings listed in the RFC are to allow you to restrict the # of
concurrent connections. However, this will be overridden by the server
if when it checks the provider and discovers that the thread model
supported is only single threaded. In the single threaded case at most
only 1 connection will be allowed at a time regardless of what the user
may have entered in the configuration settings.
Example: OsGeo.Gdal:10 means at most 10 concurrent connections, but if
the thread model checked by the server is single-threaded the server
will enforce a maximum of 1 concurrent connection and ignore this
setting as it is not valid.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer (External)
Sent: April 19, 2007 10:48 AM
To: MapGuide Internals Mail List
Subject: Re:
+0 Paul
I think it is important, but this is essentially a hack to make
things work and doesn't address the actual underlying problem.
Also, using the proposed syntax, how will multiple restrictions be
handled? The example just shows a single provider but it is
important to show how multiples could be specified.
Cheers
Paul
On 18-Apr-07, at 2:04 PM, Jason Birch wrote:
> I'm going to consider that a motion for an accelerated vote on RFC 19.
> Given the importance of this RFC, I support this motion (seconded) and
> vote +1
> Jason :)
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce
> Dechant
> Sent: Wednesday, April 18, 2007 10:55
> Subject: RE:
> Any objections to me posting this for approval sooner then after the
> typical week of discussion?
> I would like to get it into the MGOS 1.2 Beta 2.
> Thanks,
> Bruce
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the mapguide-internals
