[mapguide-internals] Context menu localization
Jason Birch Jason.Birch at nanaimo.ca
Fri Apr 27 16:53:53 EDT 2007
That feels a bit limiting.
It would seem like a good idea to somehow allow strings within the web
layout to be configured with alternate resource values, so that somebody
could put up a multilingual map :)
Not sure if there is a business case for this or not though...
Good to see that you're still following the list Alain.
Jason
-----Original Message-----
Subject: RE: [mapguide-internals] Context menu localization
 - The web layout. Commands are created and named by the user. Even
built-in command labels can be modified with MapGuide Studio. Because
those strings are user-defined you cannot localize them, only the user
can. If a user implements a web site which supports the Spanish
language, then he must supply a Spanish version of the web layout, with
localized command names inside.
More information about the mapguide-internals mailing list
