[mapguide-internals] FW: [mapguide-users] Filters cause Mapguide to crash
Jason Birch Jason.Birch at nanaimo.ca
Tue Aug 14 19:18:56 EDT 2007
Is this likely to be because of MapGuide not releasing connections
properly?
http://trac.osgeo.org/mapguide/ticket/178
Jason
Subject: Re: [mapguide-users] Filters cause Mapguide to crash
In case anyone else gets this problem - Managed to fix this issue by
including SHP and SDF in the connection pool. This is the setting in the
C:\Program Files\MapGuideOpenSource\Server\Bin\serverconfig.ini file.
You need to comment out the following :-
DataConnectionPoolExcludedProviders=
#OSGeo.SDF,OSGeo.SHP
Thanks,
Joe
Joe Maurin   wrote:
	Has anyone else seen any major issues with using Filters ?
	When I apply filters to layers in my package, it crashes the map
server process. It seems to have memory leak ? The process gets larger
as I pan around the map until it eventually crashes, dependant on the
resources of the machine. I've tested it in three seperate Windows
environments and the same thing occurs. When I remove the filters it
works fine. I have worked around the issue by filtering the data before
loading into Mapguide, but this is not ideal. I'm using 1.2 on Windows
with IIS.
	If someone else has the same issue, i'll log a bug ticket,
	Thanks,
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
More information about the mapguide-internals mailing list
