[mapguide-internals] MGOS 2.0 beta 2 candidate (again)
Tom Fukushima tom.fukushima at autodesk.com
Thu Dec 13 14:28:10 EST 2007
Hi Jason,
We tried this out and it is working for us.  However, the instructions on this page http://trac.osgeo.org/mapguide/wiki/1.2to2.0MigrationInstructions needed to be updated because of the side-by-side configuration.
The error that you were seeing happens if the 2.0 repository admin executables are used in the "BackUpOnlineRepositories.bat" and "RestoreRepositories.bat" steps.  Do you think that you might have done this?
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom Fukushima
Sent: Thursday, December 13, 2007 10:02 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MGOS 2.0 beta 2 candidate (again)
Thanks Jason.
Steve is looking into this.  It looks to me like we're installing the wrong binaries.
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, December 12, 2007 11:37 PM
wITH THE CURRENT Installer, the database upgrade does not appear to
work.  AFTER WAlking through the upgrade process, I get the following
error when starting the server:
<2007-12-12T22:27:11>                   Administrator
 Error: Cannot open repository: C:\Program
Files\MapGuideOpenSource2.0\Server\Repositories\Site\MgSiteResourceConte
nts.dbxml
        The repository version '5' does not match the current version
'6'. Upgrade is required. Please refer to documentation for details.
 StackTrace:
  - MgServer.open line 1052 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_14.2\mgdev\server\
src\core\Server.cpp
  - MgServiceManager.Initialize line 145 file
src\common\manager\ServiceManager.cpp
  - MgServerResourceService.OpenRepositories line 170 file
src\services\resource\ServerResourceService.cpp
  - MgSiteRepository.MgSiteRepository line 57 file
src\services\resource\SiteRepository.cpp
  - MgRepository.VerifyAccess line 104 file
src\services\resource\Repository.cpp    Cannot open repository:
C:\Program
nts.dbxml
The repository version '5' does not match the current version '6'.
THE upgrade process also had odd output:
(sorry for odd caps; on laggy wireless)
--- Upgrading Session repository ...
Attempting to join environment: C:\Program
positoryAdmin\..\Repositories\Session
Unable to join environment C:\Program
oryAdmin\..\Repositories\Session, creating a DB_PRIVATE environment
Container upgraded: MgSessionResourceContents.dbxml
..\bin\db_upgrade: C:\Program
Files\MapGuideOpenSource2.0\Server\RepositoryAdmin
\..\Repositories\Session\MgSessionResourceData.db upgraded successfully
--- Upgrading Site repository ...
positoryAdmin\..\Repositories\Site
Program version 4.5 doesn't match environment version 92733440.0
Error opening environment C:\Program
ryAdmin\..\Repositories\Site: DbEnv::open: DB_VERSION_MISMATCH: Database
environ
ment version mismatch
--- Upgrading Library repository ...
positoryAdmin\..\Repositories\Library
Program version 4.5 doesn't match environment version 92405760.0
ryAdmin\..\Repositories\Library: DbEnv::open: DB_VERSION_MISMATCH:
Database envi
ronment version mismatch
\..\Repositories\Library\MgLibraryResourceData.db upgraded successfully
Fukushima
Sent: Wednesday, December 12, 2007 10:21
Subject: [mapguide-internals] MGOS 2.0 beta 2 candidate (again)
I've posted the latest beta 2 candidates again at
http://download.osgeo.org/mapguide/releases/2.0.0-beta2/, and hope to do
a general announcement on the users list tomorrow morning. The BDBXML
files should also now be installed!  (Thanks Tim)
Thanks in advance if you have a chance to check things out before I post
it.
Tom
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
