[mapguide-internals] MGOS 2.0 beta 2 candidate (again)
Jason Birch Jason.Birch at nanaimo.ca
Thu Dec 13 23:24:29 EST 2007
I was getting pretty pissed off at my wireless connection by that point, so I might have screwed up.  I'm pretty sure that I did those steps on a machine that only had 1.2 installed on it though, and then copied the repositories onto my test VM to run the upgrade.  I'll try again when I get some breathing room...
Is that wiki page linked to from anywhere?
Jason
Subject: RE: [mapguide-internals] MGOS 2.0 beta 2 candidate (again)
We tried this out and it is working for us.  However, the instructions on this page http://trac.osgeo.org/mapguide/wiki/1.2to2.0MigrationInstructions needed to be updated because of the side-by-side configuration.
The error that you were seeing happens if the 2.0 repository admin executables are used in the "BackUpOnlineRepositories.bat" and "RestoreRepositories.bat" steps.  Do you think that you might have done this?
More information about the mapguide-internals mailing list
