[mapguide-internals] RE: [mapguide-users] Adding a
CoordinateSystem to MGE/MGOS
Robert Bray
rbray at robertbray.net
Fri Dec 14 22:20:21 EST 2007
The intent is not to release Mentor under LGPL, but something less strict
like MIT or BSD. That way MapServer and other open source projects can use
it freely without concern.
Bob
----- Original Message -----
From: "Bruce Dechant" <bruce.dechant at autodesk.com>
To: "MapGuide Internals Mail List" <mapguide-internals at lists.osgeo.org>
Sent: Friday, December 14, 2007 5:29 PM
Subject: RE: [mapguide-internals] RE: [mapguide-users] Adding a
> The current thinking is that we will still support both PROJ4 and Mentor.
> Perhaps a compile time flag to control which you want to use - details
> have not been worked out.
> The intention is to still release Mentor under LGPL.
> For the modifying/creating/deleting coordinate systems this is much easier
> with Mentor because the Mentor API supports it and we (Autodesk) are
> familiar with using it to do these tasks (ie: Map can already do this).
> The CS API in 2.0 currently has APIs for updating the coordinate system
> dictionaries, but the PROJ4 implementation currently throws "not
> implemented exceptions" when you try to use these APIs. We wanted to get
> the updated CSAPI framework in place so that when Mentor is open sourced
> users will be able to benefit right away. For PROJ4 it would be nice if
> someone in the open source community more familiar with PROJ4 would update
> these to actually do what is needed.
> Bruce
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
> Birch
> Sent: Friday, December 14, 2007 1:34 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] RE: [mapguide-users] Adding a Coordinate
> System to MGE/MGOS
> Is the current thinking that we pull PROJ.4 entirely out of MapGuide, or
> that we continue to support both projection engines through some kind of
> configuration?
> I see that making Mentor the default projection engine would solve a lot
> of headaches for users of Studio and Map 3D, I wonder if there may be
> users who will want to continue using PROJ.4 in MapGuide to match the CS
> transforms used in their other open source applications.
> The press releases have indicated that Mentor will be released under
> LGPL. Is that still the intention?
> Frank, (anyone?) do you have any thoughts on how PROJ.4 and Mentor will
> be co-existing in the future?
> Jason
> From: Bruce Dechant
> Subject: RE: [mapguide-users] Adding a Coordinate System to MGE/MGOS
> Once Mentor is open sourced you will be able to use the MapGuide API
> directly to add/modify/delete coordinate system definitions.
> The API is already in open source 2.0 right now it is just not hooked up
> to PROJ4.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
