[mapguide-internals] MapGuide RFC 15 - New Query Features API
Bruce Dechant bruce.dechant at autodesk.com
Fri Feb 2 19:36:37 EST 2007
Jason,
You are correct for both situations you have described.
Perhaps this needs to be optional behavior with the new APIs only
instead of forced.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: February 2, 2007 5:24 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MapGuide RFC 15 - New Query Features
API
Yes, but that means that when users select parcels at 1:10k, when they
zoom out, they will see ugly blue blobs on my beautiful map.  They might
say:  "Are they new lakes?" :-)
I'd really prefer not to have this behaviour by default.  It changes
existing behaviour for users familiar with MG 6.5, and existing MGOS/MGE
installs, requiring a certain level of end-user retraining.
What happens if they select a feature when they are zoomed out that is
not visible by default when they zoom in?  Is the detailed view obscured
by the large selection blob from a generalized feature that is not
supposed to be visible at the large scale?
Jason
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce
Dechant
Sent: Friday, February 02, 2007 16:13
API
Jason,
The following assumes you are using the existing API.
The selected parcels only show up if you zoom/pan after you have already
selected them. As soon as you do a new selection at the zoomed out level
where the parcels are not visible they will not be selected. This is
more for convenience so that you can see a parcel you have selected
while you zoom to more of an overview display.
Now if you are not careful with the NEW API you could end up with lots
of features selected. :)
Thanks,
Bruce
Birch
Sent: February 2, 2007 5:06 PM
API
I think this is a great idea, but...
Will there be any way to disable this behaviour in the viewer?  I don't
know if I want selected parcels showing up on the map at extreme zoom
levels.  Talk about ugly.
This is not a feature request.  From a cartographic standpoint I'd love
to see something like this:
Representation thresholds.  Set zoom levels where adjacent polygonal
features are merged into a single polygon, and then turn into a
symbolized point feature.  For instance, consider a Hospital:
- at 1:5000, all buildings in the hospital complex are represented, and
labelled with the word "Hospital"
- at 1:10000, these buildings are aggregated into a single rubber-band
polygon, labelled with the letter "H" in a blue circle
- at 1:15000, the hospital is represented by a letter H in a blue
circle, positioned at the center of gravity of the original features
The trick is that all just different representations of the same
feature, so selection would be maintained, and geometry operations would
be applied to the true geometry, not the simplified representation.
I'm already doing this to a certain extent manually, but it would be
nice to not have to maintain multiple copies of the same data just for
display's sake, and with this method there is no way of maintaining
selection status from one scale range to the next.
Jason
Subject: [mapguide-internals] MapGuide RFC 15 - New Query Features API
Hi Everyone,
We would like to submit the following RFC for open discussion and
comments:
http://www.osgeo.org/trac/mapguide/wiki/MapGuideRfc15
Please respond to the list with any feedback and we will be happy to
respond.
Thanks,
Bruce
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
