[mapguide-internals]MapGuideRFC 14- CartographicStylizationEngine(maybe this timeI'll get it right)
Traian Stanev traian.stanev at autodesk.com
Mon Feb 5 00:32:15 EST 2007
Here's my take. To clarify Carsten's item #1, it means to store the image attached to the SymbolDefinition resource using Set/GetResouceData.
I don't see much value of having a raster that's a component of a SymbolDefinition be a top level resource like Paul is proposing. Here is why --
(1) you should be sharing symbols, not their components
(2) you can have a symbol that just consists of one raster -- de facto giving you the equivalent of a raster resource
(3) a raster used in a symbol will be tiny, so it can be copied easily and without much overhead if you really need to use it in two places and don't want to share a SymbolDefinition.
(4) if you are going to stick rasters in the old symbol library, might as well use the new one -- see item (2) on how to do that :-)
Traian
	-----Original Message-----
	From: mapguide-internals-bounces at lists.osgeo.org on behalf of Carsten Hess
	Sent: Sun 2/4/2007 10:56 PM
	To: MapGuide Internals Mail List; MapGuide Internals Mail List
	Cc:
	Subject: RE: [mapguide-internals]MapGuideRFC 14- CartographicStylizationEngine(maybe this timeI'll get it right)
	Yeah I was looking at the same thing and don't like it. How about we create a new resource type called "RasterLibrary"?
	Cheers,
	  Carsten
	        From: mapguide-internals-bounces at lists.osgeo.org on behalf of Robert Bray
	        Sent: Sun 2/4/2007 10:11 PM
	        Cc:
	        Subject: Re: [mapguide-internals] MapGuideRFC 14- CartographicStylizationEngine(maybe this time I'll get it right)
	        Guys,
	        Here is the definition of our existing SymbolLibrary:
	        <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
	        elementFormDefault="qualified" attributeFormDefault="unqualified">
	           <xs:element name="SymbolLibrary" type="SymbolLibraryType"/>
	           <xs:complexType name="SymbolLibraryType">
	             <xs:sequence>
	               <xs:element name="Description" type="xs:string" minOccurs="0"/>
	               <xs:element name="Symbol" type="SymbolType" minOccurs="0"
	        maxOccurs="unbounded"/>
	             </xs:sequence>
	           </xs:complexType>
	           <xs:complexType name="SymbolType">
	             <xs:sequence>
	               <xs:element name="Name" type="xs:string"/>
	               <xs:element name="Resource" type="xs:string"/>
	             </xs:sequence>
	           </xs:complexType>
	        </xs:schema>
	        In looking at this I have two reservations. First is the naming which is
	        not great for re-purposing it (but I can live with it if everyone else
	        can). Second we might need to add I type element or attribute to
	        SymbolType to indicate if the binary data is a DWF, Image, or some other
	        type of future thing.
	        Bob
	        Paul Spencer wrote:
	        > Carsten,
	        > I was thinking of just the raster.  I agree with each symbol being its
	        > own resource.  I would just like to have a place to put the raster
	        > images in the repository rather than an external reference, and would
	        > prefer to have the raster images not be with the symbol so they can be
	        > potentially shared between symbols.
	        > Cheers
	        > Paul
	        > On 4-Feb-07, at 7:38 PM, Carsten Hess wrote:
	        >> Bob, Paul,
	        >> not sure I follow. Do you want to put the symbol plus all
	        >> depdendencies into the symbol library and hence build a symbol library
	        >> or do you want to put just the raster into the symbol library?
	        >> I always thought we could make a directory in the resource repository
	        >> to be a "symbol library" but each symbol be its own resource. The
	        >> reason I liked it is that I can put metadata against it and ultimately
	        >> search for the symbol (if we get around to implementing that).
	        >> Think for  example about the FGDC library, it has several hundred
	        >> symbols, searching would be useful I think.
	        >> Cheers,
	        >>   Carsten
	        >> Robert Bray
	        >>     Sent: Sun 2/4/2007 5:28 PM
	        >>     Cc:
	        >>     Subject: Re: [mapguide-internals] MapGuide RFC 14-
	        >> CartographicStylizationEngine (maybe this time I'll get it right)
	        >>     Carsten,
	        >>     I read your choice (1) as storing it with the SimpleSymbolDefinition
	        >>     using Get/SetResourceData. I think Paul is referring to storing the
	        >>     images in our existing SymbolLibrary resource, which stores a
	        >> collection
	        >>     of DWF symbols in a single resource.
	        >>     Bob
	        >>     Carsten Hess wrote:
	        >>     > Paul,
	        >>     > that is the same as my choice 1) think. We could do that. Like I
	        >> said though we have to figure out to have multiple raster in there and
	        >> how to refer to them as resource id.
	        >>     > Cheers,
	        >>     >   Carsten
	        >> of Paul Spencer (External)
	        >>     >       Sent: Sun 2/4/2007 5:03 PM
	        >>     >       Cc:
	        >>     >       Subject: Re: [mapguide-internals] MapGuide RFC 14 -
	        >>     >       Carsten,
	        >>     >       Why can you not reference it inside the existing
	        >> SymbolLibrary object
	        >>     >       in the repository?  This mechanism is already used for
	        >> point symbols
	        >>     >       and seems to fit semantically for this purpose too.  I
	        >> believe there
	        >>     >       is already a way to do this using MarkSymbolType or
	        >> something like
	        >>     >       that (I'm not looking at the schema for layer definition
	        >> so I may
	        >>     >       have that wrong)
	        >>     >       Cheers
	        >>     >       Paul
	        >>     >       On 4-Feb-07, at 3:23 PM, Carsten Hess wrote:
	        >>     >       > Hi Paul,
	        >>     >       > I think we have four choices for binary raster data:
	        >>     >       > 1) We could attach it to the symbol resource as binary data
	        >>     >       > (resource data)
	        >>     >       > 2) We could make it its own resource
	        >>     >       > 3) We could put it  somewhere on the file system
	        >>     >       > 4) We could embedd it in the XML as base64 encoded stream
	        >>     >       > Currently you find 3) only because of our prototype, we
	        >> actually
	        >>     >       > don't want to propose that. We played with some of the
	        >> XML and use
	        >>     >       > it to refer to raster via the file system. That is
	        >> easier to debug
	        >>     >       > then in the resource repository.
	        >>     >       > The schema refers to 2) and 4) I think as a possiblity
	        >> ... I
	        >>     >       > personally also like 1) but then we would have to figure
	        >> out how to
	        >>     >       > refer to it and how to put multipl raster in there.
	        >>     >       > Cheers
	        >>     >       >   Carsten
	        >> on behalf of Paul
	        >>     >       > Spencer (External)
	        >>     >       >       Sent: Sun 2/4/2007 12:22 PM
	        >>     >       >       Cc:
	        >> - Cartographic
	        >>     >       >       I notice that the first example references an
	        >> image in the Library://
	        >>     >       >       but the documentation in the proposed schema say
	        >> its a reference to
	        >>     >       >       an external image.
	        >>     >       >       Is the intention to actually reference images on
	        >> the server in an
	        >>     >       >       external location on the file system, external via
	        >> http, or actually
	        >>     >       >       to allow putting images into the repository?
	        >>     >       >       I like the idea of being able to put images such
	        >> as PNGs into the
	        >>     >       >       repository and referencing them there - but there
	        >> is no concept of
	        >>     >       >       this in the proposed schema.
	        >>     >       >       I guess, thinking about this, it would be best to
	        >> reference an image
	        >>     >       >       inside a SymbolLibrary.  What would be the
	        >> implications of this to
	        >>     >       >       your proposal?
	        >>     >       >       Cheers
	        >>     >       >       Paul
	        >>     >       >       On 2-Feb-07, at 4:29 PM, Robert Bray wrote:
	        >>     >       >       > THIS TIME SENT AS VERY PLAIN TEXT with FIXED
	        >> LINK - SORRY FOR THE
	        >>     >       >       > SPAN ALL
	        >>     >       >       > All,
	        >>     >       >       > We would like to submit the following RFC for
	        >> open discussion and
	        >>     >       >       > comments:
	        >> http://www.osgeo.org/trac/mapguide/wiki/MapGuideRfc14
	        >>     >       >       > - Note this RFC is living on our new Trac based
	        >> Wiki. The other
	        >>     >       >       > RFCs will be moving to this location shortly.
	        >>     >       >       > Please respond to the list with any feedback and
	        >> we will be happy
	        >>     >       >       > to respond.
	        >>     >       >       > Thanks,   Walt, Traian, Carsten, Jason (and
	        >> others like Bob the
	        >>     >       >       > admin assistant)
	        >>     >       >       > _______________________________________________
	        >>     >       >       > mapguide-internals mailing list
	        >>     >       >       > mapguide-internals at lists.osgeo.org
	        >> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
	        >>     >       >       |Paul Spencer
	        >> pspencer at dmsolutions.ca    |
	        >>     >       >       |Chief Technology
	        >> Officer                                         |
	        >>     >       >       |DM Solutions Group Inc
	        >> http://www.dmsolutions.ca/ |
	        >>     >       |Paul Spencer
	        >>     >       |Chief Technology
	        >> Officer                                         |
	        > |Paul Spencer                          pspencer at dmsolutions.ca    |
	        > |Chief Technology Officer                                         |
	        > |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the mapguide-internals mailing list
