[mapguide-internals] MapGuideRF 14 - CartographicStylizationEngine(again)
Traian Stanev traian.stanev at autodesk.com
Wed Feb 7 22:58:26 EST 2007
SymbolName is supposed to be the id of the symbol. We should probably rename it to SymbolID or SymbolReference.
	-----Original Message-----
	From: mapguide-internals-bounces at lists.osgeo.org on behalf of Robert Bray
	Sent: Wed 2/7/2007 9:53 PM
	To: MapGuide Internals Mail List
	Cc:
	Subject: Re: [mapguide-internals] MapGuideRF 14 - CartographicStylizationEngine(again)
	Carsten,
	Either I am blind or something is a miss. I don't see any element in
	mdf_changes_v4.xsd that refers to a Symbol. I see a <SymbolName>
	element, where I was expecting <SymbolID> or <SymbolReference>. Is the
	schema wrong or ?
	Thanks,
	Bob
	Carsten Hess wrote:
	> Hi everyone,
	> You might have already noticed we updated the draft RFC draft with some
	> new information ... here a list of what has changed:
	> - We added how the layer definition will be affected (aka how to use a
	> symbol)
	> - We generally cleaned up the samples to be actually aligned with the
	> schema (or at least they are closer we believe :))
	> - We added metadata information for parameters
	> - We added how to localize a symbol
	> We are aiming for one additional small update based on all your feedback
	> in the next couple of days before we plan on asking you for your
	> approval to start working on this for real.
	> Cheers,
	>     Carsten
	> P.S.: The updated RFC is at
	> http://www.osgeo.org/trac/mapguide/wiki/MapGuideRfc14
	> mapguide-internals mailing list
	> mapguide-internals at lists.osgeo.org
	> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
