[mapguide-internals] MapGuideRF 14 - CartographicStylizationEngine
(again)
Robert Bray
rbray at robertbray.net
Wed Feb 7 22:00:01 EST 2007
Another comment on mdf_changes_v4.xsd:
It looks like all labels in a CompositeRule have to be defined in terms
of the new symbol definitions. There does not appear to be a way to
define one based just on a simple text label (as per the existing layer
definition). Is that intentional and if so what is the rationale?
Thanks,
Bob
Carsten Hess wrote:
> Hi everyone,
> You might have already noticed we updated the draft RFC draft with some
> new information ... here a list of what has changed:
> - We added how the layer definition will be affected (aka how to use a
> symbol)
> - We generally cleaned up the samples to be actually aligned with the
> schema (or at least they are closer we believe :))
> - We added metadata information for parameters
> - We added how to localize a symbol
> We are aiming for one additional small update based on all your feedback
> in the next couple of days before we plan on asking you for your
> approval to start working on this for real.
> Cheers,
> Carsten
> P.S.: The updated RFC is at
> http://www.osgeo.org/trac/mapguide/wiki/MapGuideRfc14
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
