[mapguide-internals] DWF from MapGuide OS doesn't work in AutoCAD?
Paul Spencer
pspencer at dmsolutions.ca
Tue Feb 13 08:04:01 EST 2007
Thanks Walt ... I'll check and see if this is the case and helps, and
let everyone know.
Cheers
Paul
On 13-Feb-07, at 5:17 AM, Walt Welton-Lair wrote:
> EPlots generated using MapGuide use version 6.01 of the Whip toolkit.
> This version introduces some opcodes used explicitly by MapGuide.
> In the case where AutoCAD doesn't import this DWF I see two
> possibilities:
> - the version of AutoCAD is old and doesn't support this version of
> DWF
> / Whip
> - the version of AutoCAD is newer, but hasn't been updated to handle
> these MapGuide-specific opcodes
> I know that if your map has labels or constant-size point symbols then
> the generated EPlot will contain some of these new opcodes. Have the
> user try turning off all labeling and change all point layers to use
> "Map space" size context, and then generate an updated EPlot. Maybe
> AutoCAD will then be able to load it.
> Walt
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
> Birch
> Sent: Tuesday, February 13, 2007 4:16 AM
> To: MapGuide Internals Mail List
> Subject: RE: [mapguide-internals] DWF from MapGuide OS doesn't work in
> AutoCAD?
> You're talking about an ePlot generated with MgMapPlot?
> What version of AutoCAD is being used?
> What do you mean by Import? I think (but could easily be wrong) that
> DWFs are only available as reference layers in AutoCAD.
> Care to post a sample?
> Jason
> ________________________________
> From: mapguide-internals-bounces at lists.osgeo.org on behalf of Paul
> Spencer
> Sent: Mon 2007-02-12 5:43 PM
> Subject: [mapguide-internals] DWF from MapGuide OS doesn't work in
> AutoCAD ?
> Hi, I've got a client who is reporting that a DWF generated by MGOS
> works with the DWF viewer but won't import into AutoCAD. Is this a
> known issue? A problem with MapGuide? I suspect that AutoCAD just
> hasn't been updated to work with the DWF version being spit out by
> MGOS or something like that but would like confirmation ...
> Cheers
> Paul
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the mapguide-internals
