[mapguide-internals] MapTips fail when properties have null values?
Paul Spencer
pspencer at dmsolutions.ca
Tue Feb 20 08:58:33 EST 2007
Hi all ... I filed this as an issue in Trac but I haven't seen any
comments on it :)
Maptips fail to appear when the expression references a property that
is null for the current feature. Another feature that does not have
null values in the properties will produce a map tip.
Is this behaviour by design or a potential bug? Is there a way to
work around null values in the data by replacing them with an empty
string?
Trac ticket is:
http://mapguide.osgeo.org/trac/mapguide/ticket/3
I'm not looking for resolution, just a quick answer on whether this
is by design, a potential bug, or a configuration problem.
Cheers
Paul
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the mapguide-internals
