[mapguide-internals] MapTips fail when properties have null
values?
Jason Birch
Jason.Birch at nanaimo.ca
Tue Feb 20 11:08:51 EST 2007
I can't say that I have much insight into why this is happening.
This does mirror expected functionality in most DBMS systems, so it's
not necessarily a bad thing, but these systems also provide functions to
work around the null values, such as NVL, ISNULL, etc...
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer
Sent: Tuesday, February 20, 2007 05:59
To: MapGuide Internals Mail List
Subject: [mapguide-internals] MapTips fail when properties have null
values?
Hi all ... I filed this as an issue in Trac but I haven't seen any
comments on it :) Maptips fail to appear when the expression references
a property that is null for the current feature. Another feature that
does not have null values in the properties will produce a map tip.
Is this behaviour by design or a potential bug? Is there a way to work
around null values in the data by replacing them with an empty string?
Trac ticket is:
http://mapguide.osgeo.org/trac/mapguide/ticket/3
I'm not looking for resolution, just a quick answer on whether this is
by design, a potential bug, or a configuration problem.
Cheers
Paul
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
