[mapguide-internals] RE: Updated MapGuide RFC 14 - Cartographic Stylization Engine
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed Feb 21 10:05:44 EST 2007
After some more thought this change didn't make sense:
	Replaced the single Graphics element in SimpleSymbolDefinition
with a set of GraphicElement elements.  Each GraphicElement contains the
graphic (choice of Path, Image, or Text) and any hints for that graphic.
The Graphics element has been restored.  GraphicElement is now named
GraphicBaseType, and it's the base type for each graphic (Path, Image,
and Text).  GraphicBaseType contains the ResizeControl hint.
Also renamed BaseSymbolDefinitionType to SymbolDefinitionBaseType, but
this doesn't affect any existing XML files.
I didn't bump the schema version for this change, but the RFC was
updated.
Walt
> _____________________________________________
> From: 	Walt Welton-Lair
> Sent:	Tuesday, February 20, 2007 3:31 AM
> To:	'MapGuide Internals Mail List'
> Subject:	Updated MapGuide RFC 14 - Cartographic Stylization
> Engine
> Hi Folks,
> I've updated the stylization RFC with version 5 of the schema.  This
> version addresses feedback we've received, and adds some missing
> functionality.  Here's a list of all the schema changes that have been
> made:
> *	Removed enums from text alignment properties - they're now just
> plain strings so that expressions / parameters can be used.
> *	Fixed the list of vertical alignment options to match what we
> support.
> *	Removed the use of "px" everywhere.  Updated the documentation
> for all properties of type length to indicate "in mm".  Also updated
> the documentation for all angle properties to indicate "in degrees".
> *	Updated the SymbolName element in SymbolInstanceType.  It's been
> replaced by a choice of either an inlined SymbolDefinition or a
> SymbolReference.  This allows us to define simple line or fill styles
> for polygons without creating symbol resources in the resource
> service.  Note that this requires the MDF_Changes schema to now
> include the Symbolization schema.
> *	Added an optional LineWeightContext element to Path which
> specifies whether the line weight is with respect to the map or the
> user's display device.
> *	Renamed the ParameterName element in the SymbolInstance's
> ParameterOverrides section to ParameterIdentifier.  This makes it
> consistent with the ParameterDefinition element.
> *	Updated how labels work with CompositeRule
> *	Changes to SymbolInstance:
> *	removed the OverpostMode and AllowOverpost elements - these were
> misleading
> *	added a DrawLast element - this specifies whether the symbol is
> drawn as part of a final rendering pass
> *	added a CheckExclusionRegion element - this specifies whether
> the symbol checks if it overlaps the exclusion region before rendering
> *	added an AddToExclusionRegion element - this specifies if the
> graphical extent of the rendered symbol gets added to the exclusion
> region
> 		[The names of these new elements could still be
> improved...]
> *	Removed the Labels element from CompositeSymbolization.
> Labeling behavior is now defined using the new SymbolInstance elements
> (e.g. set DrawLast / CheckExclusionRegion / AddToExclusionRegion all
> to true).
> *	Replaced the single Graphics element in SimpleSymbolDefinition
> the graphic (choice of Path, Image, or Text) and any hints for that
> graphic.
> *	Added an optional ResizeBox element to SimpleSymbolDefinition.
> The ResizeBox has sub-elements which specify its initial position and
> size, and its grow behavior.  The growth can be limited to just X or
> Y, or both X / Y with or without maintaining aspect ratio.
> *	Added a ResizeControl hint to GraphicElement.  This hint
> determines how the element interacts with the resize box.  There are
> three possibilities:
> *	it contributes its extent to the resize box but does not react
> to a resize box change
> *	it resizes and repositions in response to a resize box change
> *	it has no interaction with the resize box
> These last two changes provide support for auto-resizing symbols.
> The existing RFC examples have been updated to reflect the new schema.
> I also added another example showing how to define an auto-resizing
> symbol.
> With this update I think we're now just about ready to make this RFC
> public and ask for official approval.
> As usual, please respond to the list with any feedback.
> Thanks,
> Walt
>  W       E         @__   __o
>    A   T   R   @___    _ \<,_
>      L           @_   (*)/ (*)
More information about the mapguide-internals mailing list
