[mapguide-internals] Motion for a vote to either accept or
rejectMapGuide RFC 15 - New Query Features API
Jason Birch
Jason.Birch at nanaimo.ca
Fri Feb 23 13:08:13 EST 2007
Before voting on this, can I confirm that the following section only applies if the IGNORESCALE=1 flag is set, and that this value will be passed down from the inital weblayout call to the mapviewer so that the behaviour can easily be changed on a per-layout basis?
"AJAX Viewer behavior will change slightly with this RFC. If the user selects one or more features on a layer, and then zooms out to a scale where that layer is not visible, the selected features will still be visible (even though other features on that layer are not). This is desirable because you can zoom out and then generate a large scale buffer around the selected feature(s) and immediately see the result. "
Jason
From: mapguide-internals-bounces at lists.osgeo.org on behalf of Bruce Dechant
Sent: Fri 2007-02-23 9:00 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Motion for a vote to either accept or rejectMapGuide RFC 15 - New Query Features API
Hi PSC members,
I motion for a vote on RFC
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc15.
+1 from me.
Thanks
Bruce
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
