[mapguide-internals] Motion for a vote to either accept
orrejectMapGuide RFC 15 - New Query Features API
Bruce Dechant
bruce.dechant at autodesk.com
Fri Feb 23 15:39:22 EST 2007
That is the new default behavior regardless of what the IGNORESCALE
setting is. If you don't want the selection you could always remove it
via the API or the user could simply click on an open space in the map.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: February 23, 2007 11:08 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Motion for a vote to either accept
Before voting on this, can I confirm that the following section only
applies if the IGNORESCALE=1 flag is set, and that this value will be
passed down from the inital weblayout call to the mapviewer so that the
behaviour can easily be changed on a per-layout basis?
"AJAX Viewer behavior will change slightly with this RFC. If the user
selects one or more features on a layer, and then zooms out to a scale
where that layer is not visible, the selected features will still be
visible (even though other features on that layer are not). This is
desirable because you can zoom out and then generate a large scale
buffer around the selected feature(s) and immediately see the result. "
Jason
From: mapguide-internals-bounces at lists.osgeo.org on behalf of Bruce
Dechant
Sent: Fri 2007-02-23 9:00 AM
Subject: [mapguide-internals] Motion for a vote to either accept or
Hi PSC members,
I motion for a vote on RFC
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc15.
+1 from me.
Thanks
Bruce
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
