[mapguide-internals] Update for MapGuide RFC 12 -
UnmanagedDataAPI Changes
Jason Birch
Jason.Birch at nanaimo.ca
Wed Feb 28 18:30:04 EST 2007
+1
makes sense to me
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
Fukushima
Sent: Wednesday, February 28, 2007 13:48
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Update for MapGuide RFC 12 -
Thanks Tony,
I motion to do accept this update.
+1 Tom
Thanks
Tom
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tony
Fang
Sent: Wednesday, February 28, 2007 1:54 PM
Subject: [mapguide-internals] Update for MapGuide RFC 12 - Unmanaged
DataAPI Changes
Dearest PSC members,
I'd like to make the following updates to MapGuide RFC 12 - Unmanaged
Data API Changes.
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc12
For a feature source, an alias must be in the form:
%MG_DATA_PATH_ALIAS[alias]%
This follows the existing conventions in the server for replacing text
tags (e.g. %MG_DATA_FILE_PATH%). The server performance will be much
better compared to using only [alias] as it will reduce the amount of
potential false-positive hits while performing the alias re-mapping.
Example:
<?xml version="1.0" encoding="utf-8"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
<Provider>OSGeo.SDF</Provider>
<Parameter>
<Name>File</Name>
<Value>%MG_DATA_PATH_ALIAS[alias1]%LIPOFGUTTER.sdf</Value>
</Parameter>
<Parameter>
<Name>ReadOnly</Name>
<Value>TRUE</Value>
</Parameter>
</FeatureSource>
For the EnumerateUnamangedData API method, the "select" parameter should
be renamed to "type". This follows the convention used by the other API
methods.
Here is the http signature for the EnumerateUnmanagedData API:
OPERATION=ENUMERATEUNMANAGEDDATA
VERSION=1.0.0
PATH=
RECURSIVE=0
TYPE=Folders
FILTER=
Thanks,
Tony Fang
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
