[mapguide-internals] Update for MapGuide RFC 12 - Unmanaged
DataAPI Changes
Paul Spencer
pspencer at dmsolutions.ca
Wed Feb 28 19:10:35 EST 2007
+1 Paul
On 28-Feb-07, at 4:48 PM, Tom Fukushima wrote:
> Thanks Tony,
> I motion to do accept this update.
> +1 Tom
> Thanks
> Tom
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tony
> Fang
> Sent: Wednesday, February 28, 2007 1:54 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] Update for MapGuide RFC 12 - Unmanaged
> DataAPI Changes
> Dearest PSC members,
> I'd like to make the following updates to MapGuide RFC 12 - Unmanaged
> Data API Changes.
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc12
> For a feature source, an alias must be in the form:
> %MG_DATA_PATH_ALIAS[alias]%
> This follows the existing conventions in the server for replacing text
> tags (e.g. %MG_DATA_FILE_PATH%). The server performance will be much
> better compared to using only [alias] as it will reduce the amount of
> potential false-positive hits while performing the alias re-mapping.
> Example:
> <?xml version="1.0" encoding="utf-8"?>
> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
> <Provider>OSGeo.SDF</Provider>
> <Parameter>
> <Name>File</Name>
> <Value>%MG_DATA_PATH_ALIAS[alias1]%LIPOFGUTTER.sdf</Value>
> </Parameter>
> <Parameter>
> <Name>ReadOnly</Name>
> <Value>TRUE</Value>
> </Parameter>
> </FeatureSource>
> For the EnumerateUnamangedData API method, the "select" parameter
> should
> be renamed to "type". This follows the convention used by the other
> API
> methods.
> Here is the http signature for the EnumerateUnmanagedData API:
> OPERATION=ENUMERATEUNMANAGEDDATA
> VERSION=1.0.0
> PATH=
> RECURSIVE=0
> TYPE=Folders
> FILTER=
> Thanks,
> Tony Fang
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the mapguide-internals
