[mapguide-internals] PATCH: fix for showing command label
insteadof command name inAJAX flyout menu
Bruce Dechant
bruce.dechant at autodesk.com
Tue Jul 3 13:04:22 EDT 2007
Thanks for creating this patch!
I have created the following trac ticket: http://trac.osgeo.org/mapguide/ticket/222
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Måns Beckman
Sent: July 3, 2007 4:30 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] PATCH: fix for showing command label insteadof command name inAJAX flyout menu
This is my first time submitting a patch so I hope that I'm doing everything correct.
When I was translating MapGuide into Swedish I found that the flyout menu in the toolbar shows the command name and not the command label set in MGS. I found where the error was and downloaded the code from the trac.
What I do is simply correcting root/trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ so that row 1037 says the same thing as 986, changing cmd.name to item.name. I think the same change should be applied to row 482 in root/trunk/MgDev/Web/src/viewerfiles/dwfmappane.templ but I haven't made a real diff for that.
Hope I got everything right now.
Cheers
Måns
Måns Beckman
Man and Machine
Fabriksgatan 13
412 50 Göteborg
Phone: +46 31 - 762 8182
Mobile: +46 733 - 38 83 19
More information about the mapguide-internals
