[mapguide-internals] First draft of MapGuide RFC 22-ReplaceFastCGI
Trevor Wekel
trevor.wekel at autodesk.com
Fri Jun 29 15:21:45 EDT 2007
I suspect our current FastCGI implementation also has an impact on PHP.
It would be worthwhile to install PHP as an isapi module or Apache mod
by default.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Ronnie
Louie
Sent: Friday, June 29, 2007 1:09 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] First draft of MapGuide RFC
22-ReplaceFastCGI
I supposed it would be prudent to still support the .exe agent in CGI
mode.
There shouldn't be any implications for PHP. As before, the php
extensions will be need to be available to the webservers via the
current installation processes.
Ronnie
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: Friday, June 29, 2007 12:32 PM
Subject: RE: [mapguide-internals] First draft of MapGuide RFC 22
-ReplaceFastCGI
YES YES YES!
The RFC mentions much of the functionality being moved from the agent to
the modules. Does this mean that it will no longer be possible to run
the .exe agent in cgi mode?
Are there any implications for PHP with this? Will we be requiring
either mod_php / isapi_php to be pre-installed by the user? I'd
personally prefer to see third party modules like Apache and PHP
unbundled from the installation, but I guess there's a lot more work
(either for the end user or for the installer designer) when it comes to
integrating with existing installs...
Jason
Louie
Sent: Friday, June 29, 2007 10:46
Subject: [mapguide-internals] First draft of MapGuide RFC 22 -
ReplaceFastCGI
Hi List,
A first draft of MapGuide RFC 22 - Replace FastCGI is posted at
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc22. Please have a look
and reply to this list with your comments.
Thanks
Ronnie
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
