[mapguide-internals] Raster Layer Default Extents
Traian Stanev traian.stanev at autodesk.com
Mon Mar 5 17:35:02 EST 2007
The problem is in the Server code.
MgServerGetSpatialContexts::GetSpatialContextData to be exact.
The DefaultRasterLocation did not show in my version of Studio until I
flagged it as "required" and recompiled the provider.
Traian
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
Fukushima
Sent: Monday, March 05, 2007 5:32 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Raster Layer Default Extents
Hi Traian,
Thanks for finding the problem. Was the problem that you mention below
in Studio?
Also, the DefaultRasterLocation property does show up in Studio's
generic feature source editor; the default editor will show both
required and optional configuration properties. Perhaps you have exposed
an issue related to your system configuration that we're not aware of.
Tom
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Monday, March 05, 2007 3:15 PM
Hi Frank.
I was able to make it work correctly. The problem was that MapGuide
(incorrectly) uses the string returned by GetCoordinateSystem() to
determine if a spatial context is defined. The GDAL provider returns
empty string for GetCoordinateSystem() so MapGuide doesn't even try to
read the values from the spatial context. I changed your
GetCoordinateSystem() to simply return the same value as the name of the
spatial context and it started working fine.
Also, I recommend making the DefaultRasterLocation property "required"
so that it shows up in the generic connection dialog in MapGuide Studio.
This way it makes it easy for someone using Studio to set up a GDAL
connection. It's strange that properties that are not explicitly
"required" don't show up in the Studio UI, but oh well.
Traian
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Frank
Warmerdam (External)
Sent: Monday, March 05, 2007 12:42 PM
Subject: Re: [mapguide-internals] Raster Layer Default Extents
Jason Birch wrote:
> Hi Frank,
> For the ADSK raster provider, it looks like image reference
information
> may be stored in a separate XML chunk, associated with the
> FeatureSource.  Perhaps MapGuide relies on this rather than the
extents
> returned from the provider?
Jason,
In this case I was using the "no xml config" option.  That is, just
giving a DefaultRasterFileLocation property value when connecting.
So there shouldn't be any alternative configuration xml.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
