[mapguide-internals] Build problems
Jason Birch Jason.Birch at nanaimo.ca
Thu Mar 15 01:13:32 EDT 2007
Just in case anyone missed it at the end of the localization message was a plea for help on SuSe.
Apparently there is a considerable uptake possibility here if we can help get it going, and the Spanish-speaking community in OSGeo looks like it's extremely active.
Frank, do you have any insights?  Would commenting out rik support possibly help?
On the other hand, I am not able to install MGOS 1.1 at SUSE 10. Chris
Gountanis sent me some steps to perform installation at
Gentoo, but it didn't work. Thanks Chris.
These are some of the errors I get when building and installing FDO:
rikdataset.cpp:590: error: 'uLong' was not declared in this scope
rikdataset.cpp:590: error: expected ';' before 'destLen'
rikdataset.cpp:591: error: 'Byte' was not declared in this scope
rikdataset.cpp:591: error: 'upsideDown' was not declared in this scope
rikdataset.cpp:591: error: expected primary-expression before ')' token
rikdataset.cpp:591: error: expected ';' before 'CPLMalloc'
rikdataset.cpp:593: error: 'destLen' was not declared in this scope
rikdataset.cpp:590: error: 'uncompress' was not declared in this scope
rikdataset.cpp:597: error: expected primary-expression before ')' token
rikdataset.cpp:591: error: expected ')' token before 'pImage'
make[2]: *** [../o/rikdataset.o] Error 1
make [2]:  Leaving directory
'/usr/OpenSource_FDO/Thirdparty/GDAL1.3/src/frmts/rik'
make [1]: *** [rik-install-obj] Error 2
make [1]: Leaving directory
'/usr/OpenSource_FDO/Thirdparty/GDAL1.3/src/frmts'
make: *** [frmts-target] Error 2
cp: cannot stat './.libs/libgdal.a' : No such file or directory
cp: cannot stat './.libs/libgdal.so' : No such file or directory
cp: cannot stat './.libs/libgdal.so.1' : No such file or directory
cp: cannot stat './.libs/libgdal.so.1.9.0' : No such file or directory
make: *** No rule to make target 'install'. Stop.
There are 20 potential clients using SUSE at their servers and they will
move to another solution/provider if I'm not successful.
Anybody can help me?
Lic. Jorge Rubio
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
