[mapguide-internals] PSC: Motion RE: Proposed minor changes to RFC14
Jason Birch Jason.Birch at nanaimo.ca
Mon Mar 19 13:05:01 EDT 2007
+1 Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
Fukushima
Sent: Monday, March 19, 2007 09:48
To: MapGuide Internals Mail List
Subject: [mapguide-internals] PSC: Motion RE: Proposed minor changes to
RFC14
Thanks Walt, these look good.
Hi PSC members,
I motion that we accept these changes to RFC 14.
+1 Tom
Thanks
Tom
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt
Welton-Lair
Sent: Thursday, March 15, 2007 9:15 AM
Subject: [mapguide-internals] Proposed minor changes to RFC 14
Now that implementation has started on RFC 14, we've come up with a list
of (mostly-minor) symbolization schema changes that need to be made.
Please have a quick look and reply if you have questions or issues.
*	remove invalid enumerations from
SymbolInstance::CheckExclusionRegion element
		=> it should be a plain xs:string
*	change SymbolInstance::SizeContext to be a SizeContextType
		=> this is for consistency
*	make LineUsage::VertexAngleLimit an xs:string type
		=> the type is missing in the schema
*	change all enumerated type properties to plain strings so they
support expressions
		=> PointUsage::AngleControl
		=> LineUsage::AngleControl
		=> LineUsage::UnitsControl
		=> LineUsage::VertexControl
		=> AreaUsage::OriginalControl
		=> AreaUsage::AngleControl
		=> AreaUsage::ClippingControl
		=> Path::LineCap
		=> Path::LineJoin
		=> GraphicBaseType::ResizeControl
		=> ResizeBox::GrowControl
*	add a VertexJoin property on LineUsage
		=> all graphic elements in the simple symbol use this
value to determine their wrapping behavior at vertices
*	rename Parameter::ValueList to AllowedValues
*	rename SimpleSymbol::SimpleSymbolReference to SymbolReference
		=> it's already clear enough that this is a
SimpleSymbolReference because this is part of SimpleSymbol
*	switch order of elements in AreaUsage
		=> switch AngleControl and OriginControl
		=> put Angle before OriginX and OriginY
		=> makes AreaUsage more consistent with LineUsage and
PointUsage
*	change Graphics collection to allow 0 to unbounded elements
		=> currently it requires at least one element
		=> users want to save their symbols while editing them
		=> they may temporarily not contain any graphic elements
*	same change for the CompoundSymbolDefinition::SimpleSymbol
collection
		=> allow 0 to unbounded symbols
*	same change for the CompositeSymbolization::SymbolInstance
collection
		=> allow 0 to unbounded symbol instances
*	rework SymbolDefinition element
		=> create separate SimpleSymbolDefinition and
CompoundSymbolDefinition elements which are of the corresponding types
		=> update SymbolInstance to have either a
SymbolReference, SimpleSymbolDefinition, or CompoundSymbolDefinition
		=> delete SymbolDefinition and SymbolDefinitionType
*	document the default value for all optional elements
*	for properties supporting expressions that must evaluate to
certain string values, document what those values are
Walt
 W       E         @__   __o
   A   T   R   @___    _ \<,_
     L           @_   (*)/ (*)
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
