[mapguide-internals] PSC: Motion RE: Proposed minor changes to
RFC14
Bruce Dechant
bruce.dechant at autodesk.com
Mon Mar 19 13:08:05 EDT 2007
+1 Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
Fukushima
Sent: March 19, 2007 10:48 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] PSC: Motion RE: Proposed minor changes to
RFC14
Thanks Walt, these look good.
Hi PSC members,
I motion that we accept these changes to RFC 14.
+1 Tom
Thanks
Tom
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt
Welton-Lair
Sent: Thursday, March 15, 2007 9:15 AM
Subject: [mapguide-internals] Proposed minor changes to RFC 14
Now that implementation has started on RFC 14, we've come up with a list
of (mostly-minor) symbolization schema changes that need to be made.
Please have a quick look and reply if you have questions or issues.
* remove invalid enumerations from
SymbolInstance::CheckExclusionRegion element
=> it should be a plain xs:string
* change SymbolInstance::SizeContext to be a SizeContextType
=> this is for consistency
* make LineUsage::VertexAngleLimit an xs:string type
=> the type is missing in the schema
* change all enumerated type properties to plain strings so they
support expressions
=> PointUsage::AngleControl
=> LineUsage::AngleControl
=> LineUsage::UnitsControl
=> LineUsage::VertexControl
=> AreaUsage::OriginalControl
=> AreaUsage::AngleControl
=> AreaUsage::ClippingControl
=> Path::LineCap
=> Path::LineJoin
=> GraphicBaseType::ResizeControl
=> ResizeBox::GrowControl
* add a VertexJoin property on LineUsage
=> all graphic elements in the simple symbol use this
value to determine their wrapping behavior at vertices
* rename Parameter::ValueList to AllowedValues
* rename SimpleSymbol::SimpleSymbolReference to SymbolReference
=> it's already clear enough that this is a
SimpleSymbolReference because this is part of SimpleSymbol
* switch order of elements in AreaUsage
=> switch AngleControl and OriginControl
=> put Angle before OriginX and OriginY
=> makes AreaUsage more consistent with LineUsage and
PointUsage
* change Graphics collection to allow 0 to unbounded elements
=> currently it requires at least one element
=> users want to save their symbols while editing them
=> they may temporarily not contain any graphic elements
* same change for the CompoundSymbolDefinition::SimpleSymbol
collection
=> allow 0 to unbounded symbols
* same change for the CompositeSymbolization::SymbolInstance
collection
=> allow 0 to unbounded symbol instances
* rework SymbolDefinition element
=> create separate SimpleSymbolDefinition and
CompoundSymbolDefinition elements which are of the corresponding types
=> update SymbolInstance to have either a
SymbolReference, SimpleSymbolDefinition, or CompoundSymbolDefinition
=> delete SymbolDefinition and SymbolDefinitionType
* document the default value for all optional elements
* for properties supporting expressions that must evaluate to
certain string values, document what those values are
Walt
W E @__ __o
A T R @___ _ \<,_
L @_ (*)/ (*)
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
