[mapguide-internals] Bug in Beta1
Walt Welton-Lair
walt.welton-lair at autodesk.com
Fri May 4 16:59:37 EDT 2007
That seems like wrong behavior in ACE_DEBUG. For release I would expect zero code to be generated.
Maybe it's documented to work that way though for debug and release. (I remember .NETs Debug.Output method behaving similarly.) If that's the case we might want to consider using something else to output debug information, rather than having to wrap all these calls with #ifdefs.
Steve - thanks for tracking this down and offering to fix it.
Walt
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org on behalf of Steve Dang
Sent: Fri 5/4/2007 10:44 PM
To: MapGuide Internals Mail List
Cc:
Subject: RE: [mapguide-internals] Bug in Beta1
I remember the issue now. With ACE_DEBUG statements, the web tier
outputs information to STD OUT under both debug and release. So, we need
to wrap ACE_DEBUG calls around with #ifdef _DEBUG's. I will fix this.
Steve.
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Steve
Dang
Sent: Friday, May 04, 2007 2:14 PM
We normally use ACE_DEBUG in the Server code only, not in the Web Tier
or Common. Does anyone recall if there is some issue with ACE_DEBUG in
the Web Tier?
Steve.
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce
Dechant
Sent: Friday, May 04, 2007 2:06 PM
The calls are helpful when running a debug server. They do not appear
when a release build is done. We should not get rid of them.
If these were appearing then somehow a debug DLL was included in the
installer.
Bruce
Dang
Sent: May 4, 2007 2:03 PM
And also this:
ACE_DEBUG((LM_DEBUG, ACE_TEXT( "(%P|%t)
MgSiteManager::Initialize()\n")));
This class is commonly used by both the Server and Web Tier, so we may
want to get rid of these ACE_DEBUG calls.
Steve.
Dechant
Sent: Friday, May 04, 2007 1:53 PM
This only appears if a debug build is being used.
This is the code piece that displays what you are seeing:
ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t)
MgSiteManager::~MgSiteManager()\n")));
Thanks,
Bruce
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt
Welton-Lair
Sent: May 4, 2007 12:03 PM
Don't enter a ticket. I'll scan the code real quick tonight, and if I
see the problem I'll add a ticket and fix it.
Jason Birch
Sent: Fri 5/4/2007 8:00 PM
Cc:
Ok, after a clean re-install it's not happening.
Should I file a bug anyway? It seems like this shouldn't be
getting
sent to PHP output under normal operations, even if error
reporting is
turned on...
Jason
Jason
Birch
Sent: Friday, May 04, 2007 10:21
Weird. Still doing it in Beta 2 on that server.
Maybe it's a setting in my PHP.ini, an old file from my upgrade,
or an
artifact of running on IIS. I'm going to try a clean install
and see if
it goes away.
J
Subject: [mapguide-internals] Bug in Beta1
... it appears to have been fixed in Beta2, but though I'd send
a note
anyway.
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
