[mapguide-internals] Bug in Beta1
Bruce Dechant
bruce.dechant at autodesk.com
Fri May 4 17:08:34 EDT 2007
After MGOS 1.2 ships I suggest we create a couple new macros to
safeguard future issues. Ie:
MG_DEBUG - this could wrap the ACE_DEBUG calls for us.
MG_ASSERT - Replace the existing asserts that are causing some grief.
I'm sure there are more, but this is a start.
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt
Welton-Lair
Sent: May 4, 2007 3:00 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Bug in Beta1
That seems like wrong behavior in ACE_DEBUG. For release I would expect
zero code to be generated.
Maybe it's documented to work that way though for debug and release. (I
remember .NETs Debug.Output method behaving similarly.) If that's the
case we might want to consider using something else to output debug
information, rather than having to wrap all these calls with #ifdefs.
Steve - thanks for tracking this down and offering to fix it.
Walt
From: mapguide-internals-bounces at lists.osgeo.org on behalf of Steve Dang
Sent: Fri 5/4/2007 10:44 PM
Cc:
I remember the issue now. With ACE_DEBUG statements, the web
tier
outputs information to STD OUT under both debug and release. So,
we need
to wrap ACE_DEBUG calls around with #ifdef _DEBUG's. I will fix
this.
Steve.
Steve
Dang
Sent: Friday, May 04, 2007 2:14 PM
We normally use ACE_DEBUG in the Server code only, not in the
Web Tier
or Common. Does anyone recall if there is some issue with
ACE_DEBUG in
the Web Tier?
Steve.
Bruce
Dechant
Sent: Friday, May 04, 2007 2:06 PM
The calls are helpful when running a debug server. They do not
appear
when a release build is done. We should not get rid of them.
If these were appearing then somehow a debug DLL was included in
the
installer.
Bruce
Steve
Dang
Sent: May 4, 2007 2:03 PM
And also this:
ACE_DEBUG((LM_DEBUG, ACE_TEXT( "(%P|%t)
MgSiteManager::Initialize()\n")));
This class is commonly used by both the Server and Web Tier, so
we may
want to get rid of these ACE_DEBUG calls.
Steve.
Bruce
Dechant
Sent: Friday, May 04, 2007 1:53 PM
This only appears if a debug build is being used.
This is the code piece that displays what you are seeing:
ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%P|%t)
MgSiteManager::~MgSiteManager()\n")));
Thanks,
Bruce
Walt
Welton-Lair
Sent: May 4, 2007 12:03 PM
Don't enter a ticket. I'll scan the code real quick tonight,
and if I
see the problem I'll add a ticket and fix it.
behalf of
Jason Birch
Sent: Fri 5/4/2007 8:00 PM
Cc:
Ok, after a clean re-install it's not happening.
Should I file a bug anyway? It seems like this
shouldn't be
getting
sent to PHP output under normal operations, even if
error
reporting is
turned on...
Jason
Behalf Of
Jason
Birch
Sent: Friday, May 04, 2007 10:21
Weird. Still doing it in Beta 2 on that server.
Maybe it's a setting in my PHP.ini, an old file from my
upgrade,
or an
artifact of running on IIS. I'm going to try a clean
install
and see if
it goes away.
J
Subject: [mapguide-internals] Bug in Beta1
... it appears to have been fixed in Beta2, but though
I'd send
a note
anyway.
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
