[mapguide-internals] Patch: Remove usage of DbXml private header
Traian Stanev traian.stanev at autodesk.com
Fri May 11 14:28:33 EDT 2007
Hi Helio,
Just for information (so that you don't get a nasty surprise), compiling against external versions of the libraries is fine, except for gd. For gd you should use the source provided by MapGuide. It's ok to use external libraries for all of gd's dependencies (jpeg, png, freetype2, etc). I recently did a build on the newest Ubuntu and I also used a mix and match of external libraries (in particular I used the libACE that was available on the machine, since the one that came with MapGuide was not compiling for some reason).
Traian
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Helio Chissini de Castro
Sent: Friday, May 11, 2007 2:18 PM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Patch: Remove usage of DbXml private header
Hi
Current in mapguide 1.2.0 beta1 Server/src/Services/Resources is using a private header from DbXml, TypeConversions.hpp, just for exclusive conversion of integer to strings.
As i'm compiling mapguide using external DbXml instead of internal provided one, i did this patch which removes the usage of wrong header and replace for some standard c++ way.
Thanks in advance
KDE Project South America Primary Contact Curitiba - Brasil
More information about the mapguide-internals mailing list
