[mapguide-internals] fdogdal, ECW, etc
Andy Morsell amorsell at spatialgis.com
Wed May 23 12:04:56 EDT 2007
That's good news, Tom.  How are things looking for MrSID, or is that already
working?
Andy
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom
Fukushima
Sent: Wednesday, May 23, 2007 8:19 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] fdogdal, ECW, etc
Hi Frank,
After changing to gdal_i.lib in our builds, the ECW support DLL that you
provided works.  The FDO team will drop this change into subversion; so we
will not need a special built DLL for the release of MGOS 1.2.0.
Others,
I have posted the patched DLL at
http://download.osgeo.org/mapguide/releases/1.2.0-beta2/GDALPatch.zip.
The file in there should replace the one found in c:\program
files\mapguideopensource\server\bin\fdo.  Give it a try, I will add
information about it at
http://wiki.osgeo.org/index.php/MapGuide_Open_Source_Using_the_Open_Sour
ce_Raster_Provider_with_Studio.
Thanks
Tom
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Frank
Warmerdam (External)
Sent: Tuesday, May 22, 2007 8:08 AM
Subject: Re: [mapguide-internals] fdogdal, ECW, etc
Tom Fukushima wrote:
> Hi Frank,
> You had mentioned in a previous email a long time ago that you had to
> change some of the build settings (to make GDAL load dynamically). Can
> you tell me what those changes were, or perhaps post the vcproj files
> that you used?
Tom,
I changed gdal.lib to gdal_i.lib in the fdogdal project files (for debug and
release versions).  This forces fdogdal to use the GDAL13.DLL instead of
statically linking stuff in.
I can't see why this should make any real difference.  I did it mainly so I
could more easily replace GDAL13.DLL with new debug builds and stuff, but
magically when I did this the plugin loading started working.
I don't know how meaningful this is.  But I would encourage it as a general
practice.
> Also, I notice that you only mention ECW below; does this mean that
> MrSID is working?
I never tried mrsid.   So, no, it does not mean that.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
