[mapguide-internals] fdogdal, ECW, etc
Tom Fukushima
tom.fukushima at autodesk.com
Wed May 23 11:18:43 EDT 2007
Hi Frank,
After changing to gdal_i.lib in our builds, the ECW support DLL that you
provided works. The FDO team will drop this change into subversion; so
we will not need a special built DLL for the release of MGOS 1.2.0.
Others,
I have posted the patched DLL at
http://download.osgeo.org/mapguide/releases/1.2.0-beta2/GDALPatch.zip.
The file in there should replace the one found in c:\program
files\mapguideopensource\server\bin\fdo. Give it a try, I will add
information about it at
http://wiki.osgeo.org/index.php/MapGuide_Open_Source_Using_the_Open_Sour
ce_Raster_Provider_with_Studio.
Thanks
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Frank
Warmerdam (External)
Sent: Tuesday, May 22, 2007 8:08 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] fdogdal, ECW, etc
Tom Fukushima wrote:
> Hi Frank,
> You had mentioned in a previous email a long time ago that you had to
> change some of the build settings (to make GDAL load dynamically). Can
> you tell me what those changes were, or perhaps post the vcproj files
> that you used?
Tom,
I changed gdal.lib to gdal_i.lib in the fdogdal project files (for debug
and release versions). This forces fdogdal to use the GDAL13.DLL
instead
of statically linking stuff in.
I can't see why this should make any real difference. I did it mainly
so I could more easily replace GDAL13.DLL with new debug builds and
stuff, but magically when I did this the plugin loading started working.
I don't know how meaningful this is. But I would encourage it as a
general practice.
> Also, I notice that you only mention ECW below; does this mean that
> MrSID is working?
I never tried mrsid. So, no, it does not mean that.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGeo,
http://osgeo.org
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
