[mapguide-internals] A RFC proposal
Kenneth, GEOGRAF A/S
ks at geograf.dk
Thu May 24 07:22:55 EDT 2007
I would like to propose a Rfc:
Currencly, the runtime map is stored on the server as an attachment to a
dummy resource in the session repository. This version of the map is in
a binary format, and is thus not easily accessible by thirdparty
software (eg. not using the server API).
I suppose the internal format is used for speed concerns. If that is the
case, it would be unwise to remove the internal usage of the binary format.
As the map definition is already defined as Xml and used in the library
repository, there should be a method to convert the binary format to xml
and vice versa. If this option was avalible from the Web API, one could
disregard this internal format, and avoid creating binary serializers
and deserializers.
If the coversion allowed updating an existing binary format with xml,
the changelists in the binary format could also be updated the reflect
the difference between the two versions, and everything should work as
before.
The two methods i propose in the Web API are:
GetXmlMap(string resourceid)
SetXmlMap(string resourceid, bool create)
The resourceid should point to an existing dummy resource, that contains
the current runtime map, eg "Session:???//Map1.Map".
The create parameter can be used to overwrite the map, or update it.
Regards, Kenneth, GEOGRAF A/S
More information about the mapguide-internals
