[mapguide-internals] Error in compiling Agg on ubuntu...
Jason Birch Jason.Birch at nanaimo.ca
Fri Nov 9 17:57:35 EST 2007
I'm running into a problem in the build_apt.sh process.
It's looking for SSL and Curl.  These appear to be installed as part of
FDO, but MapGuide is not finding them.
Is it better for me to apt-get them, or to somehow reference the FDO
ThirdParty components?
If the latter, how do I do that? :)
Jason
-----Original Message-----
Subject: RE: [mapguide-internals] Error in compiling Agg on ubuntu...
Some of the packages you are explicitly installing (xerces, xalan, curl,
and some others) are already available as part of the Oem build and you
should not need to apt-get them. The instructions are a lot more
comprehensive than what I usually do -- I wrestle with the build until
it works. Now I know why I have to replace /bin/sh from all the scripts
by /bin/bash. :)
I wonder why you apt-get asound -- my bet is that you are avoiding a
build error with DWF that way.
More information about the mapguide-internals mailing list
