[mapguide-internals] Mgserver doesn't start in daemon mode
afterreboot
Jason Birch
Jason.Birch at nanaimo.ca
Tue Nov 13 16:50:59 EST 2007
I went ahead and added this as a ticket too:
http://trac.osgeo.org/mapguide/ticket/309
Jason
-----Original Message-----
Subject: [mapguide-internals] Mgserver doesn't start in daemon mode
afterreboot
After a "make install" on mapguide, I can run this sequence to start and
stop MapGuide many times, with no problems:
After a reboot, this no longer works; the daemon mode does not start up
the server in the background properly. Interactive mode works fine.
If I then run "make install" again and try the above sequence the daemon
starts up properly in the background.
Is "make install" setting up an environment variable or something that
I'm missing out on?
More information about the mapguide-internals
