[mapguide-internals] Mgserver doesn't start in daemon mode
afterreboot
Tim Strang
tim.strang at autodesk.com
Tue Nov 13 16:53:42 EST 2007
OK, I will fix that too. Who assigns me to this ticket?
Thanks,
Tim
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Tuesday, November 13, 2007 4:51 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Mgserver doesn't start in daemon mode afterreboot
I went ahead and added this as a ticket too:
http://trac.osgeo.org/mapguide/ticket/309
Jason
Subject: [mapguide-internals] Mgserver doesn't start in daemon mode
afterreboot
After a "make install" on mapguide, I can run this sequence to start and
stop MapGuide many times, with no problems:
After a reboot, this no longer works; the daemon mode does not start up
the server in the background properly. Interactive mode works fine.
If I then run "make install" again and try the above sequence the daemon
starts up properly in the background.
Is "make install" setting up an environment variable or something that
I'm missing out on?
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
