[mapguide-internals] MapStudio Open Source
Kenneth, GEOGRAF A/S ks at geograf.dk
Sun Nov 18 08:37:33 EST 2007
Thanks for posting the link :D.
I did put the Cut/Copy/Paste in the context menu, and I will put the
New/Delete there as well.
There is a Keep-Alive timer, to prevent the Session expiration, but it
would be more stable to have an auto-reconnect feature.
It should be fairly easy to put in a "Connect to site..." menu, I will
put it in there.
I did think about an edit for the ResourceData, but I can't determine if
the ResourceStream always indicates a text file, or if it could be a
binary stream.
The problem should be resolved, once I get around to creating the
FeatureSource editor for ODBC datasources, as the name is constant in
that provider.
I can see the problem with the SDF files, it must be some encoding
problem with the "%" sign.
I will look into it.
I wrote "no bug reports", because I know of many bugs, and because I
don't have tools to organize a large number of bug reports.
I you send bug reports, I will most likely look into it, but there is no
promise :D
Thanks for trying it out.
Regards, Kenneth, GEOGRAF A/S
Jason Birch skrev:
> Hi Kenneth,
> You said no bug reports, so I'm keeping quiet :)
> Couple feature suggestions:
>  - Session maintenance:  currently, if the session expires the only way to reestablish seems to be to restart the application.  If the app gets a "session expired" exception it would be nice if it could automatically attempt to obtain a new one.
>  - Connection management:  it would be nice to be able to connect to a different server without having to restart the app
>  - Right-click functionality:  I'd love to see all of the New/Delete/Copy/Paste/etc functionality available in the context menu.  Buttons don't get along with me
>  - I love that you can edit the XML files directly at any level.  It would also be nice to be able to edit the ResourceData (ConfigurationDocument) in place.
> OK one weird one...  testing a data connection against an SDF file that had been loaded with a LoadProcedure threw an FDO exception:
>   <Parameter>
>     <Name>File</Name>
>     <Value>%MG_DATA_FILE_PATH%bc_border.sdf</Value>
>   </Parameter>
> Jason
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
