[mapguide-internals] MGOS 2.0.0 Beta 1 posted
formapguide-internals
Steve Dang
steve.dang at autodesk.com
Mon Nov 19 14:39:43 EST 2007
Just in case you could not open the attachment, here are the instructions on how to upgrade from 1.2 to 2.0:
Hi List,
Oracle Berkeley DB XML 2.3 has been integrated into MG code base.
Here are the manual steps on how to upgrade:
1. Shut down the existing MG Server (MG Enterprise 2008 or MG OS 1.2.x) if it is running.
2. Change to the RepositoryAdmin directory (e.g. "C:\Program Files\Autodesk\MapGuideEnterprise2008\Server\RepositoryAdmin" or "/usr/local/mapguide/server/RepositoryAdmin", etc.).
3. Run BackUpOnlineRepositories.bat (or BackUpOnlineRepositories.sh for Linux).
4. Run RestoreRepositories.bat (or RestoreRepositories.sh for Linux).
5. If you wish, you can un-install the existing MG Server. Note that the existing repositories will not get removed.
6. Install the new MG Server (MG Enterprise 2009 or MG OS 2.0.0). Note that the Server will fail to start if it tries to open old repositories.
7. Shut down the newly installed Server if it started successfully (because it created new repositories at a different install location).
8. If the new MG Server is installed on a different location than the old one, delete the Repositories directory (e.g. "C:\Program Files\Autodesk\MapGuideEnterprise2009\Server\Repositories"), then copy/move the old Repositories to the new location (e.g. "C:\Program Files\Autodesk\MapGuideEnterprise2008\Server\Repositories" --> "C:\Program Files\Autodesk\MapGuideEnterprise2009\Server\Repositories").
9. Change to the RepositoryAdmin directory (e.g. "C:\Program Files\Autodesk\MapGuideEnterprise2009\Server\RepositoryAdmin" or "/usr/local/mapguide/server/RepositoryAdmin", etc.).
10. Run UpgradeRepositories.bat (or UpgradeRepositories.sh for Linux).
11. Run SetupRepositoryIndices.bat (or SetupRepositoryIndices.sh for Linux).
Note that these steps could take longer time if you have large repositories. Please let me know if you encountered any problem.
Thanks.
Steve.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Steve Dang
Sent: Monday, November 19, 2007 12:35 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MGOS 2.0.0 Beta 1 posted formapguide-internals
Hi Jason,
Here are the default paths to:
2.0 repositories:
MGE - Windows: C:\Program Files\Autodesk\MapGuideEnterprise2009\Server\Repositories
MGOS - Windows: C:\Program Files\MapGuideOpenSource\Server\Repositories
MGE - Linux: /opt/Autodesk/mapguideenterprise2009/Server/Repositories
MGOS - Linux: /usr/local/mapguide/Server/Repositories
1.2 repositories:
MGE - Windows: C:\Program Files\Autodesk\MapGuideEnterprise2008\Server\Repositories
MGE - Linux: /opt/Autodesk/mapguideenterprise2008/Server/Repositories
The attached email shows instructions on how to upgrade from 1.2 to 2.0.
2.0 should import 1.2/1.1/1.0 MPG files properly.
Thanks,
Steve.
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, November 19, 2007 11:50 AM
Tom,
What's the migration path from 1.2 to 2.0, especially around repositories?
If I install 2.0 after uninstalling 1.2, will it take care of the repository upgrade for me?
Will 2.0 properly import 1.2 (or 1.1, or 1.0) mgp files?
(trying to figure out the easiest way of playing with my existing data under 2.0)
Thanks,
Jason
Subject: [mapguide-internals] MGOS 2.0.0 Beta 1 posted formapguide-internals
I've posted what a candidate for MGOS 2.0.0 Beta 1 to http://download.osgeo.org/mapguide/releases/2.0.0-beta1/
Please try it out before I put it out for general consumption.
You should...
1) Install the server and web tier
2) Stop the "MapGuide Server v2.0" service
3) Copy the ExpressionEngine.dll found in the ExpressionEngine.zip
file to C:\Program Files\MapGuideOpenSource\Server\Bin\FDO
4) Start the "MapGuide Server v2.0" service
5) Load the samples/SheboyganWithFlexibleLayouts.mgp
6) Try out the following URLs:
a.
http://<machinename>:8008/mapguide/fusion/templates/mapguide/slate/index
.html?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexib
leLayouts%2fSlate.ApplicationDefinition<http://%3cmachinename%3e:8008/ma
pguide/fusion/templates/mapguide/slate/index.html?ApplicationDefinition=
Library%3a%2f%2fSamples%2fSheboygan%2fFlexibleLayouts%2fSlate.Applicatio
nDefinition>
b.
http://<machinename>:8008/mapguide/fusion/templates/mapguide/aqua/index.
html?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexibl
eLayouts%2fAqua.ApplicationDefinition<http://%3cmachinename%3e:8008/mapg
uide/fusion/templates/mapguide/aqua/index.html?ApplicationDefinition=Lib
rary%3a%2f%2fSamples%2fSheboygan%2fFlexibleLayouts%2fAqua.ApplicationDef
inition>
c. http://
<machinename>:8008/mapguide/fusion/templates/mapguide/limegold/index.htm
l?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexibleLa
youts%2fLimeGold.ApplicationDefinition<http://callt72xpvm:8008/mapguide/
fusion/templates/mapguide/limegold/index.html?ApplicationDefinition=Libr
ary%3a%2f%2fSamples%2fSheboygan%2fFlexibleLayouts%2fLimeGold.Application
Definition>
d. http://
<machinename>:8008/mapguide/fusion/templates/mapguide/maroon/index.html?
ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexibleLayo
uts%2fMaroon.ApplicationDefinition<http://callt72xpvm:8008/mapguide/fusi
on/templates/mapguide/maroon/index.html?ApplicationDefinition=Library%3a
%2f%2fSamples%2fSheboygan%2fFlexibleLayouts%2fMaroon.ApplicationDefiniti
on>
e.
http://<machinename>:8008/mapguide/fusion/templates/mapguide/turquoiseye
llow/index.html?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboyga
n%2fFlexibleLayouts%2fTurquoiseYellow.ApplicationDefinition<http://%3cma
chinename%3e:8008/mapguide/fusion/templates/mapguide/turquoiseyellow/ind
ex.html?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlex
ibleLayouts%2fTurquoiseYellow.ApplicationDefinition>
To get Autodesk MapGuide Studio 2008 to work with MGOS 2.0, you will need to extract the file in Autodesk.MapGuide.Studio.Site.zip found at http://download.osgeo.org/mapguide/patches/mapguidestudio/2.0.0/ForAutod
eskMapGuideStudio2008/ to C:\Program Files\Autodesk\MapGuideStudio2008.
Note: Studio 2008 does not show the new Fusion ApplicationDefinition resource in the site explorer.
I've tested out Sheboygan and a few raster formats (JPG, PNG, GIF).
Unfortunately, I just remembered to ask Frank for the ECW and MrSID format support (FDO moved to GDAL 1.4 so we need new plugins) today so support for that doesn't exist yet.
Thanks for your time!
Tom
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
