[mapguide-internals] MGOS 2.0.0 Beta 1 posted
formapguide-internals
Steve Dang
steve.dang at autodesk.com
Mon Nov 19 14:34:45 EST 2007
Hi Jason,
Here are the default paths to:
2.0 repositories:
MGE - Windows: C:\Program Files\Autodesk\MapGuideEnterprise2009\Server\Repositories
MGOS - Windows: C:\Program Files\MapGuideOpenSource\Server\Repositories
MGE - Linux: /opt/Autodesk/mapguideenterprise2009/Server/Repositories
MGOS - Linux: /usr/local/mapguide/Server/Repositories
1.2 repositories:
MGE - Windows: C:\Program Files\Autodesk\MapGuideEnterprise2008\Server\Repositories
MGE - Linux: /opt/Autodesk/mapguideenterprise2008/Server/Repositories
The attached email shows instructions on how to upgrade from 1.2 to 2.0.
2.0 should import 1.2/1.1/1.0 MPG files properly.
Thanks,
Steve.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, November 19, 2007 11:50 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MGOS 2.0.0 Beta 1 posted formapguide-internals
Tom,
What's the migration path from 1.2 to 2.0, especially around
repositories?
If I install 2.0 after uninstalling 1.2, will it take care of the
repository upgrade for me?
Will 2.0 properly import 1.2 (or 1.1, or 1.0) mgp files?
(trying to figure out the easiest way of playing with my existing data
under 2.0)
Thanks,
Jason
Subject: [mapguide-internals] MGOS 2.0.0 Beta 1 posted
I've posted what a candidate for MGOS 2.0.0 Beta 1 to
http://download.osgeo.org/mapguide/releases/2.0.0-beta1/
Please try it out before I put it out for general consumption.
You should...
1) Install the server and web tier
2) Stop the "MapGuide Server v2.0" service
3) Copy the ExpressionEngine.dll found in the ExpressionEngine.zip
file to C:\Program Files\MapGuideOpenSource\Server\Bin\FDO
4) Start the "MapGuide Server v2.0" service
5) Load the samples/SheboyganWithFlexibleLayouts.mgp
6) Try out the following URLs:
a.
http://<machinename>:8008/mapguide/fusion/templates/mapguide/slate/index
.html?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexib
leLayouts%2fSlate.ApplicationDefinition<http://%3cmachinename%3e:8008/ma
pguide/fusion/templates/mapguide/slate/index.html?ApplicationDefinition=
Library%3a%2f%2fSamples%2fSheboygan%2fFlexibleLayouts%2fSlate.Applicatio
nDefinition>
b.
http://<machinename>:8008/mapguide/fusion/templates/mapguide/aqua/index.
html?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexibl
eLayouts%2fAqua.ApplicationDefinition<http://%3cmachinename%3e:8008/mapg
uide/fusion/templates/mapguide/aqua/index.html?ApplicationDefinition=Lib
rary%3a%2f%2fSamples%2fSheboygan%2fFlexibleLayouts%2fAqua.ApplicationDef
inition>
c. http://
<machinename>:8008/mapguide/fusion/templates/mapguide/limegold/index.htm
l?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexibleLa
youts%2fLimeGold.ApplicationDefinition<http://callt72xpvm:8008/mapguide/
fusion/templates/mapguide/limegold/index.html?ApplicationDefinition=Libr
ary%3a%2f%2fSamples%2fSheboygan%2fFlexibleLayouts%2fLimeGold.Application
Definition>
d. http://
<machinename>:8008/mapguide/fusion/templates/mapguide/maroon/index.html?
ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlexibleLayo
uts%2fMaroon.ApplicationDefinition<http://callt72xpvm:8008/mapguide/fusi
on/templates/mapguide/maroon/index.html?ApplicationDefinition=Library%3a
%2f%2fSamples%2fSheboygan%2fFlexibleLayouts%2fMaroon.ApplicationDefiniti
on>
e.
http://<machinename>:8008/mapguide/fusion/templates/mapguide/turquoiseye
llow/index.html?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboyga
n%2fFlexibleLayouts%2fTurquoiseYellow.ApplicationDefinition<http://%3cma
chinename%3e:8008/mapguide/fusion/templates/mapguide/turquoiseyellow/ind
ex.html?ApplicationDefinition=Library%3a%2f%2fSamples%2fSheboygan%2fFlex
ibleLayouts%2fTurquoiseYellow.ApplicationDefinition>
To get Autodesk MapGuide Studio 2008 to work with MGOS 2.0, you will
need to extract the file in Autodesk.MapGuide.Studio.Site.zip found at
http://download.osgeo.org/mapguide/patches/mapguidestudio/2.0.0/ForAutod
eskMapGuideStudio2008/ to C:\Program Files\Autodesk\MapGuideStudio2008.
Note: Studio 2008 does not show the new Fusion ApplicationDefinition
resource in the site explorer.
I've tested out Sheboygan and a few raster formats (JPG, PNG, GIF).
Unfortunately, I just remembered to ask Frank for the ECW and MrSID
format support (FDO moved to GDAL 1.4 so we need new plugins) today so
support for that doesn't exist yet.
Thanks for your time!
Tom
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
