[mapguide-internals] MGOS 2.0.0 Beta 1postedformapguide-internals
Zac Spitzer zac.spitzer at gmail.com
Wed Nov 21 05:35:41 EST 2007
won't fly, I get a there's another version of this product installed
and it exits
z
On Nov 21, 2007 8:58 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> Thanks Jason!
> I'm going to download this beta and try it out now...
> out of interest how are the service's named, will they clash? I'm
> thinking specifically apacheMapguide
> Now that i think about it, I always found the naming of that service
> to be strange. Mapguide Apache would have the two
> related services side by side under services.
> Zac
> On Nov 21, 2007 7:36 PM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> > Hi Zak,
> > There's no official way of doing it, but at least two workarounds.  The first was to extract the MSI from the setup file, and then specify an INSTALLDIR parameter when running msiexec.  The second, which I just discovered tonight and seems a bit less hackish, is to specify the msiexec options as a parameter to the setup file (watch word wrap - there are only two commands here):
> >  MgServerSetup-2.0.0Beta1.exe /V"INSTALLDIR=\"C:\\Program Files\\MapGuideOpenSource2.0.0b1\\Server\""
> >  MgWebServerExtensionsSetup-2.0.0Beta1.exe /V"INSTALLDIR=\"C:\\Program Files\\MapGuideOpenSource2.0.0b1\\WebServerExtensions\""
> > I'm not sure if the back-end service ports have changed with MapGuide 2.0.  If they have not, you will need to go into your serverconfig.ini and webconfig.ini files and set some alternates.
> > Jason
> > ________________________________
> > From: Zac Spitzer
> > Subject: Re: [mapguide-internals] MGOS 2.0.0 Beta 1postedformapguide-internals
> > does the installer allow installing to a different directory yet?
> > I would like to have both 1.20 and the beta running on my laptop
> > mapguide-internals mailing list
> > mapguide-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer
> http://zacster.blogspot.com/
> +61 405 847 168 (aussie moible)
Zac Spitzer
More information about the mapguide-internals mailing list
