[mapguide-internals] FW: [mapguide-users] Mapguide 2.0 Beta1 vs 1.2 performance
Traian Stanev traian.stanev at autodesk.com
Wed Nov 21 20:03:33 EST 2007
In order to find out if the AGG renderer is causing the performance hit for your map, you can switch back to GD by setting the Renderer option in serverconfig.ini to GD and time it like that.
Traian
________________________________________
From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
Sent: Wednesday, November 21, 2007 5:57 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] FW: [mapguide-users] Mapguide 2.0 Beta1 vs    1.2 performance
The performance difference can be attributed to the fact that this is a Beta version being compared to a Release version.
Some things to consider:
- 1.2 used the GD renderer, whereas, 2.0 is using the new AGG renderer (looks much better)
- there are several places in the code that have not been optimized yet (algorithms, memory usage, thread usage, etc...)
- Fusion is a brand new feature of the 2.0 release and has not been optimized either
- this is a Beta and doesn't necessarily reflect the final release code. :)
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul Spencer (External)
Sent: November 21, 2007 6:25 AM
Subject: Re: [mapguide-internals] FW: [mapguide-users] Mapguide 2.0 Beta1 vs 1.2 performance
Anyone else have a feeling for relative performance of 1.2 vs 2.0 vs
2.0 w/ Fusion?  I saw it installed on a laptop yesterday, running full
screen with no tiling and the Sheboygan sample, and it was panning and
zooming in milliseconds (there was barely a flash).  Everything was on
the same machine, so there was no network latency.
Note that Fusion, in particular, is probably not optimized for initial
load in this beta.  But run-time performance should be at least on par
with the 2.0 default viewer.
Cheers
Paul
On 21-Nov-07, at 4:34 AM, Jason Birch wrote:
> In case there are folks on Internals that aren't watching Users...
> From: Bruno Scott
> Subject: [mapguide-users] Mapguide 2.0 Beta1 vs 1.2 performance
> I have 2 identical vm-ware with windows 2003 running on the same
> machine
> I start one of the vm-ware, I do the testing, I stop it and then
> start the
> other to do the other bench Bench is done on the sheboygan sample at
> 1:5000
> scale
>        MG 2.0 with fusion              Mg 2.0 without
> fusion           Mg 1.2
> pan     29 sec                  12 sec                          2 sec
> select  28 sec                  12 sec                          2 sec
> I know it's only a beta but why is that slow?
> Bruno Scott
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the mapguide-internals mailing list
