[mapguide-internals] FW: [mapguide-users] Mapguide 2.0 Beta1 vs 1.2 performance
Bruce Dechant bruce.dechant at autodesk.com
Wed Nov 21 17:57:47 EST 2007
The performance difference can be attributed to the fact that this is a Beta version being compared to a Release version.
Some things to consider:
- 1.2 used the GD renderer, whereas, 2.0 is using the new AGG renderer (looks much better)
- there are several places in the code that have not been optimized yet (algorithms, memory usage, thread usage, etc...)
- Fusion is a brand new feature of the 2.0 release and has not been optimized either
- this is a Beta and doesn't necessarily reflect the final release code. :)
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul Spencer (External)
Sent: November 21, 2007 6:25 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] FW: [mapguide-users] Mapguide 2.0 Beta1 vs 1.2 performance
Anyone else have a feeling for relative performance of 1.2 vs 2.0 vs
2.0 w/ Fusion?  I saw it installed on a laptop yesterday, running full
screen with no tiling and the Sheboygan sample, and it was panning and
zooming in milliseconds (there was barely a flash).  Everything was on
the same machine, so there was no network latency.
Note that Fusion, in particular, is probably not optimized for initial
load in this beta.  But run-time performance should be at least on par
with the 2.0 default viewer.
Cheers
Paul
On 21-Nov-07, at 4:34 AM, Jason Birch wrote:
> In case there are folks on Internals that aren't watching Users...
> ________________________________
> From: Bruno Scott
> Subject: [mapguide-users] Mapguide 2.0 Beta1 vs 1.2 performance
> I have 2 identical vm-ware with windows 2003 running on the same
> machine
> I start one of the vm-ware, I do the testing, I stop it and then
> start the
> other to do the other bench Bench is done on the sheboygan sample at
> 1:5000
> scale
>        MG 2.0 with fusion              Mg 2.0 without
> fusion           Mg 1.2
> pan     29 sec                  12 sec                          2 sec
> select  28 sec                  12 sec                          2 sec
> I know it's only a beta but why is that slow?
> Bruno Scott
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the mapguide-internals mailing list
