[mapguide-internals] RE: Blue Highlight
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue Oct 2 03:17:02 EDT 2007
You can see how to do it here:
http://discussion.autodesk.com/thread.jspa?threadID=520707
I sort of remember someone doing this runtime, but I can't find the thread.
Regards, Kenneth, GEOGRAF A/S
Crispin @ 1Spatial skrev:
> That *is* just the ticket.
> I worked it through whilst on a long train journey last night and was going
> to post the same today... so I will instead confirm it is the GERenderer m_
> variable that seems to count.
> Only on AJAX though - I have red-dashed and light red flod fill in AJAX but
> still solid-blue on DWF/Active-X.  The DWF highlight is obviously
> client-side as it has enough geometry to rebuild... so where is the setting
> here?
>  Crispin
> http://www.nabble.com/file/p12993789/Highlight.png
> JasonBirch wrote:
>> Doh, I should have refreshed my message view before hunting through the
>> code for this:
>> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Common/Renderers/GDRenderer.cpp#L1487
>> I'll update the ticket...
>> Jason
>> ________________________________
>> From: Traian Stanev
>> Subject: RE: [mapguide-internals] Blue Highlight
>> There is a very similar function in the GDRenderer.cpp that you would also
>> need to modify.
>> The one in SE_Renderer is used for the new symbology stuff only. If you
>> were using an old-style, erm, style, then you would need to modify
>> GDRenderer. Look for the function SetRenderSelectionMode.
>> Traian
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
