[mapguide-internals] RESTful Ramblings of a Restless Lunatic
Robert Bray
rbray at robertbray.net
Tue Oct 9 13:36:06 EDT 2007
I have no objection to the bracket approach for parameters. The main
aspect of my proposal was around using the resources as RESTful
resources and supporting alternate representations. If you buy this
approach feel free to simply hack the alternate parameter spec approach
along side the existing ones in the same WIKI page. That way it will be
easier to compare/contrast the two styles. If the whole resource model
is different then a different page would be more appropriate.
Feel free to fix those PUT and POSTs while you are at it :)
Bob
Jason Birch wrote:
> The more I think about this stuff, the more I'm leaning towards Haris'
> initial practice of using [] to indicate filters/parameters applied at
> each level of the resource. I believe that the benefits of this
> notation outweigh the fact that it doesn't look like a filesystem. For
> instance, your feature can look like either /feature[2352] or
> /feature[zone=%22RS-1%22] or
> /feature[http%3A%2F%2Fmgserver%2Fmgrest%2Fsession%5B215tge54356%5D%2Ffil
> ter%5B32654%5D] (which is pointing at
> http://mgserver/mgrest/session[215tge54356]/filter[32654]). I haven't
> had time to do this yet, but I think that it would be worthwhile to set
> up a parallel wiki page that shows how this implementation would work.
> As an aside, it appears that there are quite a few areas of the current
> wiki that are still using PUT instead of POST where relevant.
> Jason
> -----Original Message-----
> From: Robert Bray
> Subject: Re: [mapguide-internals] RESTful Ramblings of a Restless
> Lunatic
> Actually it is possible to have multiple selections per runtime map.
> Only one can be rendered at a time at the moment, but you can have
> multiple. They are currently defined to be a seperate session bound
> resource type.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
