[mapguide-internals] RESTful Ramblings of a Restless Lunatic
Jason Birch
Jason.Birch at nanaimo.ca
Thu Oct 11 14:52:19 EDT 2007
The one that is not encoding it is behaving illegally :)
The BNF-like description section of the spec contains the following
(fairly clear) wording: The "national" and "punctuation" characters do
not appear in any productions and therefore may not appear in URIs.
And national is defined as: { } | [ ] \ ^ ~
I see your point about encoding/decoding I guess, but I'd hate to use a
separator that couldn't be easily distinguished in the URL string. It
would make troubleshooting difficult.
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Thursday, October 11, 2007 11:25
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] RESTful Ramblings of a Restless
Lunatic
Regarding [ ] characters, two major browser's behavious differently, IE
and Firefox, one will encoded one will not.
Any how , those characters are interpreted normally by browser and
server.
Regarding encoded I believe that at the end when we will develope all
functionality ( sql queries, spatial filters, MapGuide identifiers,..)
REST URI will certainly not look "nicely" to human eye.
I think that is something which is not that important and after
implmenting RESTfull principles beside first-entering URI, other URI's
will not be important to user or application.
I think it is important that URI parser undoubltly and quickly can
identify resources in URI path, but that doens' mean it is nessecceray
[] combination.
I saw some suggestion's to use ! in path to separate filter part.
Haris
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: Thursday, October 11, 2007 7:25 PM
Lunatic
You're absolutely right Bob (well, from my reading anyway), reference
here:
http://www.w3.org/Addressing/URL/uri-spec.html
The character doesn't really matter to me, but I don't want to see it
being encoded. Basically, we just need a common way of separating the
resource from the filter.
Looks like the only open/close option is standard parens (), but there
are a lot of single delimiter such as $ or @
To avoid problems, it would be nice if we could choose a delimiter that
is not a valid resource names in MapGuide if possible. Any suggestions?
Now you're going to tell me that MapGuide allows any URI-valid
characters :)
Jason
Subject: Re: [mapguide-internals] RESTful Ramblings of a Restless
Lunatic
I just did some checking and the way I read the URI specification (RFC
3986) square brackets [ ] are not valid within the path portion of a
URI. Hence they would need to be encoded as %5B and %5D.
Someone else should probably look and validate that. I decided to check
because I have never seen brackets used within a URI path before, and
non-standard syntax always raises a flag in my head.
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
