[mapguide-internals] MapGuide RESTful Web Service prototype
Jason Birch
Jason.Birch at nanaimo.ca
Fri Sep 14 11:20:24 EDT 2007
I don't suppose that you have the calls to the API documented?
If you can provide a link to download the isapi extension, that would be
cool.
I know that this is alpha, but thought I'd pass along a couple viewer
comments.
In IE:
- Legend updates don't seem to trigger a refresh immediately, the way
they do in FF
- Selection throws an error
Jason
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Friday, September 14, 2007 06:37
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MapGuide RESTful Web Service prototype
Few more things:
- Our server has very limited output bandwidth so (I would encourage to
install it on your desktop and server)
- Works with IE 7 and Firefox
Simon just told me that we made mistake when putting viewer on web, when
I made first post, now it should be ok.
Haris
Kurtagic
Sent: Friday, September 14, 2007 3:11 PM
Subject: [mapguide-internals] MapGuide RESTful Web Service prototype
Simon and I have build first protoype of MapGuide RESTful service.
You can get more info here www.sl-king.com/mgrest
Main Features:
* Use MapGuide as RESTful service
* Run MapGuide viewer from desktop
* No need for web tier (php ,java ,net)
* Use simultaneously same Map in different views or use Maps from
different sites in one viewer
* Add to existing MapGuide functionality - backward compatible
* ISAPI extension with HTTP keep-alive connection implemented with
pool of worker threads
Download viewer from
http://www.sl-king.com/mgrest/download/MgRestViewer_0_1.rar
There is a viewer which is served from our web server
http://www.sl-king.com/mgrestviewer
but I will encourage you to download viewer ( html and js) and run it
from desktop.
Comments are very much welcomed.
Thanks,
Haris
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
