[mapguide-internals] MapGuide RESTful Web Service prototype
Haris Kurtagic haris at sl-king.com
Fri Sep 14 13:32:00 EDT 2007
For legend I can see it , it is like you need to do additional click on
legend panel.
Selection throws error in some cases (not all) that is known case.
Now we are using JSONP for this and the way string is created (I am
using existing MapQueryFeatures XML to JSON) doesn't fit to JSONP.
Also selection is by mistake fixed to parcels only now.
I will document and post implemented REST requests in a while.
I have tried it in Safari beta 3 for Windows and it looks like working (
Safari seems really fast).
Haris
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: Friday, September 14, 2007 5:20 PM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] MapGuide RESTful Web Service prototype
I don't suppose that you have the calls to the API documented?
If you can provide a link to download the isapi extension, that would be
cool.
I know that this is alpha, but thought I'd pass along a couple viewer
comments.
In IE:
 - Legend updates don't seem to trigger a refresh immediately, the way
they do in FF
 - Selection throws an error
Jason
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: Friday, September 14, 2007 06:37
Few more things:
- Our server has very limited output bandwidth so (I would encourage to
install it on your desktop and server)
- Works with IE 7 and Firefox
Simon just told me that we made mistake when putting viewer on web, when
I made first post, now it should be ok.
Haris
Kurtagic
Sent: Friday, September 14, 2007 3:11 PM
Subject: [mapguide-internals] MapGuide RESTful Web Service prototype
Simon and I have build first protoype of MapGuide RESTful service.
You can get more info here www.sl-king.com/mgrest
Main Features:
*	Use MapGuide as RESTful service
*	Run MapGuide viewer from desktop
*	No need for web tier (php ,java ,net)
*	Use simultaneously same Map in different views or use Maps from
different sites in one viewer
*	Add to existing MapGuide functionality - backward compatible
*	ISAPI extension with HTTP keep-alive connection implemented with
pool of worker threads
Download viewer from
http://www.sl-king.com/mgrest/download/MgRestViewer_0_1.rar
There is a viewer which is served from our web server
http://www.sl-king.com/mgrestviewer
but I will encourage you to download viewer ( html and js) and run it
from desktop.
Comments are very much welcomed.
Thanks,
Haris
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
