[mapguide-internals] MapGuide LGPL license
Kenneth, GEOGRAF A/S
ks at geograf.dk
Fri Apr 4 11:06:59 EDT 2008
I was wondering how it is possible for Autodesk to build and distribute
modified LGPL code?
I am not objecting to this, and I believe it is fair that Autodesk earns
a revenue, as they are the primary funders for the project.
I am currious, because the idea of providing source code to others, but
maintaining a "pro" binary is commercially interresting in some aspects.
I also belive that Autodesk has done the legal homework, and I am not a
lawyer :).
I have read the LGPL some times, and it clearly states that you may use
unmodified LGPL code, only if it is a "work that uses the Library".
Otherwise, the entire source code must be published including the
modifications.
The "work that uses the Library" part is a little weak, but I have an
understanding that Autodesk applies some internal patches before
releasing the code.
Is it simply because Autodesk retains the original copyright, so they
can do as they wish?
Regards, Kenneth, GEOGRAF A/S
More information about the mapguide-internals
