[mapguide-internals] Why are some FDO providers missing fromthe
MapGuide installation?
Kenneth, GEOGRAF A/S
ks at geograf.dk
Sun Apr 6 05:20:13 EDT 2008
No, I have only had a quick go at both.
The main advantage with WiX is that it builds MSI packages, which can be
loaded in Citrix and other systems easily.
The main advantage of NSIS, is that it does not use the MSI system, and
is thus easier to control (IMO), but it produces .exe files, which may
not be easily integrated into all package distribution systems.
For MapGuide the use in an automated installation system is probably
limited, and I would go for NSIS there.
Regards, Kenneth, GEOGRAF A/S
Jason Birch skrev:
> I'm going to be looking at building an NSIS installer for MGOS, hopefully in the next month or so but don't hold me to that...
> I've also been considering whether WiX is a better choice, but it seems a bit less flexible.
> Do you have any experience with either or a different open source install builder?
> Jason
> ________________________________
> From: Kenneth, GEOGRAF A/S
> Subject: Re: [mapguide-internals] Why are some FDO providers missing fromthe MapGuide installation?
> Who is maintaining the merge modules for the existing providers?
> I can try to create merge modules for the other providers, if I get some
> starting ground.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
