[mapguide-internals] MapGuide RFC 55 - Switch from
PROJ4toCS-Mapcoordinate system library
Maksim Sestic
max at geoinova.com
Mon Aug 11 10:07:39 EDT 2008
:-) Thanks Jason, it's much more clear now. BTW, way to go!
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, August 11, 2008 15:58
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] MapGuide RFC 55 - Switch from
Maksim,
Mentor==CS-Map (one is the company name, the other is the library) so there
should be no issues.
Jason
----- Original Message -----
<mapguide-internals-bounces at lists.osgeo.org>
To: 'MapGuide Internals Mail List' <mapguide-internals at lists.osgeo.org>
Sent: Mon Aug 11 03:02:58 2008
Subject: RE: [mapguide-internals] MapGuide RFC 55 - Switch from PROJ4
Hi all,
Aside from potential extra work at existing sites, is there any information
on how switch from PROJ4 toCS-Map might affect Autodesk MapGuide Enterprise
developers - in correlation with Map 3D which, if I recall right, utilizes
Mentor library for CRS management? Since RFC is obviously funded by
Autodesk, I presume they're also heading for some sort of unified CRS data
access, based on OSGeo solution (?) There's no rumors/info on it on ADN
channels either.
Regards,
Maksim Sestic
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Crispin @
1Spatial
Sent: Monday, August 11, 2008 11:50
Subject: Re: [mapguide-internals] MapGuide RFC 55 - Switch from PROJ4
toCS-Map coordinate system library
I have three comments here...
1) Excellent! - I think this is a great opportunity but...
2) I am concerned that this is a major update and that for existing sites
there will need to be a migration similar to the DBXML upgrade from 1.2 to
2. This means that for 2.x sites there will be a (possibly) considerable
amount of authoring layers and maps. For those of us just looking for an
Opnera/FF3 compatible release this major migration is going to cause some
effort, certainly worth it in the long-run but can there be a final 2.0.2
release before committing to CS-Map in 2.1?
3) Based on the size of the SVN for CS-Map - there are some support files
of 10s of MB - how will the installer be built? Will there be a seperate
download for the additional support files? The 'Dictionaries' folder is
about 300MB uncompressed.
Crispin
View this message in context:
http://www.nabble.com/MapGuide-RFC-55---Switch-from-PROJ4-to-CS-Map-coordina
te-system-library-tp18882286p18922721.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
__________ NOD32 3301 (20080727) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
More information about the mapguide-internals
