[mapguide-internals] MapGuide RFC 55 - Switch from
PROJ4toCS-Mapcoordinate system library
Hugues Wisniewski
hugues.wisniewski at autodesk.com
Mon Aug 11 12:42:17 EDT 2008
Hi Maksim,
Jason is right
Autodesk MapGuide Enterprise and Autocad Map will remain the same.
The CS-Map code that was written by Mentor Software Inc which was acquired last year by Autodesk is the one that was recently posted on OSGEO. If this RFC is approved, MapGuide open source as well as Autodesk MapGuide Enterprise and Autocad Map will use the same copy of CS-Map.
So, from an Autodesk MapGuide Enterprise and Autocad Map, end user's point of view there will be absolutely no change.
Hugues
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
Sent: Monday, August 11, 2008 7:08 AM
To: 'MapGuide Internals Mail List'
Subject: RE: [mapguide-internals] MapGuide RFC 55 - Switch from PROJ4toCS-Mapcoordinate system library
:-) Thanks Jason, it's much more clear now. BTW, way to go!
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, August 11, 2008 15:58
To: mapguide-internals at lists.osgeo.org
Subject: Re: [mapguide-internals] MapGuide RFC 55 - Switch from
Maksim,
Mentor==CS-Map (one is the company name, the other is the library) so there
should be no issues.
Jason
----- Original Message -----
<mapguide-internals-bounces at lists.osgeo.org>
To: 'MapGuide Internals Mail List' <mapguide-internals at lists.osgeo.org>
Sent: Mon Aug 11 03:02:58 2008
Hi all,
Aside from potential extra work at existing sites, is there any information
on how switch from PROJ4 toCS-Map might affect Autodesk MapGuide Enterprise
developers - in correlation with Map 3D which, if I recall right, utilizes
Mentor library for CRS management? Since RFC is obviously funded by
Autodesk, I presume they're also heading for some sort of unified CRS data
access, based on OSGeo solution (?) There's no rumors/info on it on ADN
channels either.
Regards,
Maksim Sestic
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Crispin @
1Spatial
Sent: Monday, August 11, 2008 11:50
Subject: Re: [mapguide-internals] MapGuide RFC 55 - Switch from PROJ4
toCS-Map coordinate system library
I have three comments here...
1) Excellent! - I think this is a great opportunity but...
2) I am concerned that this is a major update and that for existing sites
there will need to be a migration similar to the DBXML upgrade from 1.2 to
2. This means that for 2.x sites there will be a (possibly) considerable
amount of authoring layers and maps. For those of us just looking for an
Opnera/FF3 compatible release this major migration is going to cause some
effort, certainly worth it in the long-run but can there be a final 2.0.2
release before committing to CS-Map in 2.1?
3) Based on the size of the SVN for CS-Map - there are some support files
of 10s of MB - how will the installer be built? Will there be a seperate
download for the additional support files? The 'Dictionaries' folder is
about 300MB uncompressed.
Crispin
View this message in context:
http://www.nabble.com/MapGuide-RFC-55---Switch-from-PROJ4-to-CS-Map-coordina
te-system-library-tp18882286p18922721.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
__________ NOD32 3301 (20080727) Information __________
This message was checked by NOD32 antivirus system.
http://www.eset.com
More information about the mapguide-internals
