[mapguide-internals] MapGuide RFC 55 - Switch from PROJ4 to CS-Map coordinate system library
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Aug 12 09:22:24 EDT 2008
Given the previous detailed information on compiling MapGuide with
PROJ.4 support, would
it be possible to provide a compiled MgGeometry.dll with PROJ.4 for
download and use with 2.1?
Or possibly the other way around, provide the compiled CS-Map MgGeometry
dll as an add-on?
If suggestion 1 is chosen, it is possible to make a low-impact upgrade,
with limited dedication from OSGeo.
Most user will just upgrade, and hapilly use CS-Map without observing
the difference.
The unlucky users, can either deal with the problems, or postpone them
for the 3.0 (or 2.2 relase),
but be aware that the problems are there.
Regards, Kenneth Skovhede, GEOGRAF A/S
Crispin @ 1Spatial skrev:
> ... inline ...
> Hi Crispin,
>> Can there be a final 2.0.2 release before committing to CS-Map in 2.1?
> What would you like to see in that 2.0.2 release? A choice between PROJ4 and
> CS-Map?
>>>> Ask someone what they want and it is always everything!  Ideally a final
>>>> Proj4 release to make 2.x a stable and accessible platform for existing
>>>> sites.  I do see CS-Map implementation as more than a .dot release and
>>>> certainly http://trac.osgeo.org/mapguide/roadmap has defined 2.1 as just
>>>> a performance, fix and message releas for 6 months now.  Changing 2.1 to
>>>> a include CS-Map really seems like a 3.0.  I want to see CS-Map come
>>>> along but managed.  Does OSGeo have the resources to support MG with
>>>> Proj.4 up to a 2.1 release in parallel with a CS-Map at 3.0 and onwards?
>> Will there be a seperate download for the additional support files?  The
>> 'Dictionaries' folder is about 300MB uncompressed.
> Are we talking about the end user installer?
> If you install MapGuide server using the Windows installer, I believe the
> installer will take care of installing all it needs. That would indeed
> inflate the size of the installer.
>>>> I see the 11g release folder from Mentor (Map 2009) is only 8MB without
>>>> the country grid files but still 132MB on disk which could seriously
>>>> inflate the Windows installer.  Certainly would be beneficial to not
>>>> have all the country grid folders as default as they are, by definition,
>>>> of regional interest.
More information about the mapguide-internals mailing list
