[mapguide-internals] MapGuide RFC 55 - Switch from PROJ4 to CS-Map coordinate system library
Crispin at 1Spatial Crispin.Hoult at 1Spatial.com
Tue Aug 12 06:50:41 EDT 2008
... inline ...
Hi Crispin,
> Can there be a final 2.0.2 release before committing to CS-Map in 2.1?
What would you like to see in that 2.0.2 release? A choice between PROJ4 and
CS-Map?
>>> Ask someone what they want and it is always everything!  Ideally a final
>>> Proj4 release to make 2.x a stable and accessible platform for existing
>>> sites.  I do see CS-Map implementation as more than a .dot release and
>>> certainly http://trac.osgeo.org/mapguide/roadmap has defined 2.1 as just
>>> a performance, fix and message releas for 6 months now.  Changing 2.1 to
>>> a include CS-Map really seems like a 3.0.  I want to see CS-Map come
>>> along but managed.  Does OSGeo have the resources to support MG with
>>> Proj.4 up to a 2.1 release in parallel with a CS-Map at 3.0 and onwards?
> Will there be a seperate download for the additional support files?  The
> 'Dictionaries' folder is about 300MB uncompressed.
Are we talking about the end user installer?
If you install MapGuide server using the Windows installer, I believe the
installer will take care of installing all it needs. That would indeed
inflate the size of the installer.
>>> I see the 11g release folder from Mentor (Map 2009) is only 8MB without
>>> the country grid files but still 132MB on disk which could seriously
>>> inflate the Windows installer.  Certainly would be beneficial to not
>>> have all the country grid folders as default as they are, by definition,
>>> of regional interest.
View this message in context: http://www.nabble.com/MapGuide-RFC-55---Switch-from-PROJ4-to-CS-Map-coordinate-system-library-tp18882286p18941904.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
